What is 8kgs in lb
What is 8kgs in 1b
  • 7,993 Answers
1 kg=2.2 lb
8 kg= 8*2.2 lb= ? lb
Posted on Mar 30, 2014
What is the motor hp?
Please see below courtesy of engineeringtoolbox.com
Electrical power is in general rated in watt (W) or horsepower (HP). A horsepower is a unit of power equal to 746 watts or 33000 lb ft per minute (or 550 lb ft per second).
A watt is equal to the power produced by a current of 1 amp across the potential difference of 1 volt. A watt is 1/746 of 1 horsepower.
Even if the watt is the base unit of electrical power, it is common to rate motor power in either horsepower or kilowatts.
Power in Watts
Direct Current Electric power supply to a direct current (DC) motor:
PkW = ?m U I / 1000 (1)
where
PkW = power (kW)
?m = motor efficiency
U = voltage (V)
I = current (A, amps)
Electric power supply to a alternating current (AC) motor:
Single Phase PkW = ?m U I PF / 1000 (1b)
where
PF = Power Factor
Two Phase Four Wire PkW = ?m 2 U I PF / 1000 (1c)
Three Phase PkW = ?m 1.73 U I PF / 1000 (1d)
Power in Horsepower
Horse power can be expressed as:
Php = PkW / 0.746 (2)
or
Php = (?m U I / 1000) / 0.746
= ?m U I / 746 (2b)
where
Php = horsepower (hp)
Feb 03, 2016 | Boating
How do I activate the auto el on a Casio 350 1b
Hello there. I don't know what 'auto el' is but if it is not in the manual, it doesn't do it !!!!
Manual on the Casio GD-350-1b here http://www.casio-intl.com/asia-mea/en/wat/watch_detail/GD-350-1B/
On this page, 1) click 'operatiion guide' 2) agree to terms 3) download the pdf format manual.
Good luck
Sep 10, 2014 | Casio Watches
How to get cheats for gta5
You enter these while in game. Not in the pause menu.
Give Item: Parachute Left, Right, LB, LT, RB, RT, RT, Left, Left, Right, LB Player Cheat: 5 Minute Invincibility Right, A, Right, Left, Right, RB, Right, Left, A, Y Player Cheat: Drunk Y, Right, Right, Left, Right, X, B, Left Player Cheat: Explosive Melee Attacks Right, Left, A, Y, RB, B, B, B, LT Player Cheat: Explosive Rounds Right, X, A, Left, RB, RT, Left, Right, Right, LB, LB, LB Player Cheat: Fast Run Y, Left, Right, Right, LT, LB, X Player Cheat: Fast Swim Left Left LB Right Right RT Left LT Right Player Cheat: Flame Round LB, RB, X, RB, Left, RT, RB, Left, X, Right, LB, LB Player Cheat: Give Weapons/Ammo Y, RT, Left, LB, A, Right, Y, Down, X, LB, LB, LB Player Cheat: Max Health & Armor B, LB, Y, RT, A, X, B, Right, X, LB, LB, LB Player Cheat: Recharge Special Ability A, A, X, RB, LB, A, Right, Left, A Player Cheat: Skyfall (Spawn in the sky) LB, LT, RB, RT, LEFT, RIGHT, LEFT, RIGHT, LB, LT, RB, RT, LEFT, RIGHT, LEFT, RIGHT Player Cheat: Slo Mo Aiming X LT RB Y Left X LT Right A Player Cheat: Super Jump Left, Left, Y, Y, Right, Right, Left, Right, X, RB, RT Player Cheat: Wanted Level - Lower RB, RB, B, RT, Right, Left, Right, Left, Right, Left Player Cheat: Wanted Level - Raise RB, RB, B, RT, Left, Right, Left, Right, Left, Right Spawn Vehicle: BMX Left Left Right Right Left Right X B Y RB RT Spawn Vehicle: Buzzard B, B, LB, B, B, B, LB, LT, RB, Y, B, Y Spawn Vehicle: Caddy B, LB, Left, RB, LT, A, RB, LB, B, A Spawn Vehicle: Comet RB, B, RT, Right, LB, LT, A, A, X, RB Spawn Vehicle: Duster Right ,Left, RB, RB, RB, Left, Y, Y, A, B, LB, LB Spawn Vehicle: Limo RT, Right, LT, Left, Left, RB, LB, B, Right Spawn Vehicle: PCJ RB Right Left Right RT Left Right X Right LT LB LB Spawn Vehicle: Rapid GT RT, LB, B, Right, LB, RB, Right, Left, B, RT Spawn Vehicle: Sanchez B, A, LB, B, B, LB, B, RB, RT, LT, LB, LB Spawn Vehicle: Stunt Plane B, Right, LB, LT, Left, RB, LB, LB, Left, Left, A, Y Spawn Vehicle: Trashmaster B, RB, B, RB, Left, Left, RB, LB, B, Right World Cheat: Change Weather RT, A, LB, LB, LT, LT, LT, X World Cheat: Moon Gravity Left Left LB RB LB Right Left LB Left World Cheat: Slippery Streets Y, RB, RB, Left, RB, LB, RT, LB World Cheat: Slow Motion Y, Left, Right, Right, X, RT, RB
Jul 27, 2014 | Video Game Consoles & Games
Cheats for gta5
You enter these while playing the game. Not in the pause menu.
Max harvest retrying
Likely cause,
1. Ice bridge thickness too small, not enough ice to open curtain.
Solution, Check and adjust if needed.
2.Ice bridge thickness too large, ice frozen to evaporator frame.
3. Purge valve dose not open, water melts ice bridge, not enough ice to open curtain.
Solution, Check purge valve.
4. Incomplete ice formation.
Solution, check water distribution for partially plugged holes.
5. Curtain out of position.
Solution, check curtain for swing restriction.
6. Curtain switch dose not open when curtain does.
Solution, Check switch with ohmmeter.
7. Machine in very cold ambient area.
Solution, Move machine to warmer location.
8. Hot gas valve dose not open.
Solution, Check hot gas valve, check controller using test mode.
9. Harvest assist probe out of position - ejector pin not retracted.
Solution, check harvest assist mechanism-spring should retract pin.
10. Damaged evaporator.
Solution, Check evaporator surface now would be a good time to make sure evaporator plate is not dirty this will cause ice to hang up on evaporator plate also check plate to make sure all cross points are not loose.
11. Fan motor stays on during harvest.
Solution, check controller using test mode.
Jul 18, 2013 | Scotsman HD22B-C0322MA-1B Hotel / Motel...
MY SCOTSMAN ICE MACHINE CO33O FREEZING CYCLE IS TOO SHORT AND IS MAKING THIN ICE
There is usually a sensor that the cubes will touch after the cubes thickness builds to a certain point. This sensor should be adjustible.
Dec 04, 2012 | Scotsman C0330SA 1B 300 lb Cube Ice...
I need to unlock an at&t nokia 6750-1b for free
Need a password code to unlock my nokia 6750-1b please
voodoo2323@rambler.ru
Aug 22, 2012 | Nokia Cell Phones
Restriction code for nokia 2730c-1b type RM-579 IC 661AB-RM579 FCC ID:QTLRM-579 IMEI: 356058/03/742191/2 code:0588611GR14r2K
sir help me about the restriction code for nokia 2730c-1b type RM-579 IC 661AB-RM579 FCC ID:QTLRM-579 I bought it from canada and it was powered by bell now im here at the Philippines i cant use my nokia 2730c-1b please help
IMEI:355935/04/073943/3 CODE: 0588611AS22i7l
my email add: ronacabugao@yahoo.com/seart98@yahoo.com
Jan 08, 2011 | Nokia 2730 Cell Phone
32 people viewed this question
jasbo
jasbo
