Question about Coby TF-TV3217 32 in. LCD TV
No power were do I find power board replacement for this tv
Replaced power supply board and main board on Element ELDFW462 TV.Now I have no power on TV.Can you help me?
Contact any service technician. This is not a service work; can be done with ease by a customer. Especially who is not aware in electronics. Gopakumar Gopalan Google
Jan 04, 2015 | Element Televison & Video
Spot of bad weather here, just had a power surge in the house and now our tv (sharp lc-42SB48UT) won't power on. There is no blue or red light on the front and changing outlets/surge protectors doesn't...
90% to 95% ur tv have a dead power supply board only.5% ur tv could have both dead boards the tv power supply board and the main tv Tuner signal board too.The tv power supply board.That the board,where the power a/c cord plug into it.The tv main Tuner signal board,that the board where all the exstented devices and the tv incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first.The tv problems should be fixed.If not than the main tv Tuner signal board is dead too.Must be replaced also.
Apr 24, 2011 | Sharp LC42SB48UT 42 in. LCD TV
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Picture went out and no audio, red light on power blinks seven times and repeats.
blink 7 times?
Yes
No
(See precaution #3)
Yes
No
Yes
No
(See precaution #3)
(See precaution #3)
(See precaution #3)
No
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
My Samsung SP-R4232 has some type of power supply issue. I called a tech who came out and verified it. He thought it was the main power board, but wanted $400 to fix it when I found the part online for...
U replaced the tv power supply board,the board u replaced,that is the board where the power a/c cord plug into it?Check ur old power supply board,examines all parts,see if u have any capactors parts are bulging or puffing up on it tops.Yes,than it is power supply board issue.But by replacing the power supply board only get 50/50 chances for the tv to work.Might be the problems,might not be the power supply board issue alone some times.The chances are tv Tuner signal board is dead also.That the board,where the tv incomming broadcasting signal cable plug into it.Try website like Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 04, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
Tv was struck by lightning, will not come on. will power supply board fix this
Well,now the tv have power to it at all?Or the tv power light indication LED light,just flashes?Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Might solved ur problem,by replacing the power supply board,might not but the power supply board,must be replaced first see,what happen to the tv.
Sep 19, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
TV won't turn on, flashing light ?
Ur tv the power supply board is dead.That the board where the power a/c cord plug into it.That the power supply board,replaced it.U will have stable power,ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 29, 2010 | Toshiba REGZA 47HL167 TV
No Power
Take ur tv aparts.Ur tv power supply board,that the board where the power a/c cord plug into it.That is ur power supply board.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 28, 2010 | Olevia LT42HVi 42 in. LCD Television
Power light is flashing green. i hold the power button it turns red. i press it again it turns yellowish then solid gree the screen comes on the 3 second later screen goes blank and flashing green power
Sharp tv are famous for this problems.Take ur tv aparts,where the a/c power cord go into it.That ur tv power supply board,check for all those dead leakage capacitors parts that bulges up on it top or puff up on it top.Than it ur power supply board,replaced those dead leakages capicitors or replaced the whole power supply board.No leakage capcitors on the power supply board.Than it 100% the Tuner board it dead,this board is where the coalax broacast tv signal cable go into it.This board can't not be repair only replaced,because it alway some ICS it the problems it dead on this Tuner board.Tries websties like Shopjimmy.com,Ebay.com to buy either or both refurbishes the power supply board or the Tuner board.
May 26, 2010 | Sharp LC32D47UT 32 in TV
Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Dec 30, 2009 | Samsung LN-T4665F 46 in. LCD Television
Coby TF-TV3217 32 in. LCD TV Logo
32 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
