Question about Kenmore Washing Machines
Coin trap location on A kenmore 90 series washing machine
90 series coin trap location
  • 1028 Answers
SOURCE: MY 90 SERIES KENMORE WASHING
if agitator mounted pull off ..may be blue ring at base if so pull up and lift dispenser off or newer type twist off..soak in hot water and flush out if front mounted dispenser clean as good as possible
Posted on Apr 27, 2008
mikedurland
  • 481 Answers
SOURCE: my washing machine
  • first thing to check is the lid switch.
  • if the lid switch is bad it will fill up, then agitate then sit there full of water.
Posted on Jul 07, 2008
  • 262 Answers
SOURCE: Remove agitator on Kenmore 90 series
ok take the top off the agitator there is a cap carefully remove this cap and then some have a inner cap with a handle remove that also in side the agitator it has a 1/2" or 7/16" head bolt remove the bolt and then pull up really ******* the agitator. to replace dogs you have to break the taps holding them in not the agitator be careful
Posted on Jan 11, 2009
SOURCE: open coin trap
use side of spanner to open the circular water drain plug on coin trap, remove all water.
use flat screwdriver to lift yellow tab at top of coin trap whiloe turning coin trap anticlockwise.
Posted on Mar 10, 2009
  • 864 Answers
SOURCE: kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
Posted on May 31, 2009
I have a Kenmore 70 series Washing machine top load model 110 serial number 82870120 . where is the lint trap located and how to take out to clean? clothes have a lot of lint after being washed.
It is likely that a tissue or paper product was included with the wash load. The series 70 does not have a lint trap. At the hose connection to the house drain lint has been known to build up restricting the emptying. This buildup would not introduce lint into the washer.
If the water temperature is very very cold and you use powder detergent it will not dissolve completely into the water and will leave a white residue on the fabrics.
Try running a short load in the washer allowing for ample water to rinse out the machine before the next wash load.
Dec 28, 2015 | Kenmore series 70 80 90 Washer timer...
Where is the coin trap on my frigidaire affinity
Hello Friend, this is Z. That's a great question!
I understand you are seeking the location of the coin trap on your Frigidaire Affinity washer. Typically, the coin trap is located inside the sump to pump hose, inside the cabinet and under the tub. Hope this information helps to some degree! If there is anything else that I can help you with, please feel free to reconnect!
May 24, 2014 | Frigidaire ATF6000ES Front Load Washer
Kenmore 90 series washer won't drain and go to spin cycle
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front, screws beneath; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp (or unscrew) that connects the trap assembly to the pump and clean it out.
If helped pl say so.
Apr 02, 2013 | Kenmore 15864/15862 Top Load Washer
Kenmore 417.43042200 Front load washer. Replace shock absorbers and coin trap
Hello Karen,
The following video should fully explain everything that you should know on how to do this replacement and any warnings.
Good Luck!
Rich Lilja
Apr 27, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore 90 series is leaking water from the bottom? How can I fix this?
TILT THE MACHINE BACK AND LOOK AT THE (WHITE) PUMP IN FRONT. SOMETIMES A COIN OR SOMETHING WILL GET STUCK NEXT TO THE IMPELLORS AND WEAR A HOLE IN THE PUMP
Oct 28, 2009 | Washing Machines
Kenmore washing machine series 90 is leaking
May 31, 2009 | Washing Machines
Open coin trap
Mar 05, 2009 | Dyson Memory CRO1 Front Load Washer
Kenmore 90 Series: Clothes very wet after spin cycle
I do not have this kind of washer, but I had same problem with my washer and I found the drain trap was full not allowing washer to completely drain. Hope this helps, Good Luck!
Feb 13, 2009 | Kenmore 23822 Top Load Washer
Washer Kenmore 90 Series
yes it has a lint trapped ..its on the bottom of wash basket,,its part of the wash basket..when the unit washes it traps the lint when the unit goes in to spin it shoots it down the drain,,i dont advice taking that out unless your a tech..now what you can do is fill unit with hot water and about a pint of bleach and let that do the work its also good for pipes,,this technic should have been a process 1 amonth ..
Dec 22, 2008 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
