Question about Samsung RS2630SH Side by Side Refrigerator
Trying to find defrost timer on samsung SRS610HDSS
Trying to locate the defrost timer for replacement
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: hi im tring to locate the defrost timer in my
Go to here for diagram:
Have your mod number ready
http://www.searspartsdirect.com/partsdirect/index.action
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 06, 2010
Defrost timer
The defrost timer is part of the electronic control baord located on the back of the refrigerator. If the freezer is not defrosting check the thermistor on the evaporator(freezer) coils. It can cause the control board to thing it doesn'y need defrosting. a common problem
Mar 22, 2014 | Kenmore Side by Side Refrigerator
Compressor and fan stop working
There is a possibility that the defrost timer turned the compressor and fans off and stuck in the defrost lobe of the defrost timer. I want you to try turning the defrost timer slowly clockwise. The defrost timer is in location 257 behind the control panel inside the fresh food compartment. Here is a photo of the parts location HERE
If doing this causes the refrigerator to work again then replace the=> WR9X489 Defrost Timer
If this does not work I want you to try something else so let me know what happens Thanks
Sea Breeze
Apr 05, 2013 | GE Profile Performance 25.2 cu. ft....
We have a samsung rf266abbp and the freezer is ultra frosty. this just started this week. the unit is about 1 year old. does it need to be defrosted. if so, how?
Hi, if freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model)
Take care
May 13, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
My Samsung side by side fridge is not cooling properly. The freezer is fine but the refrigerator does not cool enough. I cleaned it recentley but just wiped it down - nothing odd
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
Aug 11, 2009 | Refrigerators
Trying to physicaly locate defrost timer model# F44N21CEWO
Hello, This model has a mechanical timer which is located inside the console where the cold controls are located. You will find this inside the fridge. There is a small dial on the timer for advancing the timer into defrost cycle. Most of the time there is an opening/hole for access to the dial without pulling the console out. If you can't locate the hole pull the cosole out, should be a few screws. Good Luck!!!! If you have any further questions or concerns please feel free to comment again. Mike
Jul 24, 2009 | Frigidaire Refrigerators
How do i locate the defrost timer on my refrigerator?
I'm having the same problem.I checked out my fridge and found the defrost heater bad. I replaced it and also replaced the defrost thermostat. It fixed it for about 4 days and then the problem reocurred. I strongly believe that one of the relays that are built into the circuit board are going bad or getting stuck. I just hate to replace the board and have the same problem again. But, i have already replaced all other components of the defrost system, so the circuit board can only be the problem. I'm going to give it a shot.
Oct 19, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge part of my fridge freezer appears to have stopped working
Look to the freezer for your problem. Frost free refrigerators are cooled by air from the freezer compartment. If the freezer cooling coil freezes up air flow to the refrigerator is lost. Look for signs of frost on back wall of the freezer section.
Located the defrost timer, turn the clutch head screw clockwise SLOWLY until you hear one audible click. The system will then be in the defrost mode. During the 18-22 minutes of the defrost cycle heaters are energized and defrost should take place. If defrost happens and the timer does not restart into the cooling mode, rotate the screw one more time SLOWLY to the second click and the system will restart in the cooling mode. Replace the timer in this case.
If the timer restarts the cooling after the defrost period and defrost does not happen your problem is in the defrost heaters or defrost thermostat. They are located inside the back wall of the freezer on the cooling coil.
Jul 05, 2008 | Samsung Refrigerators
Rs21/fcns fridge freezer fridge keeps icing up causing fan to jam on ice and water to freeze
I have a Samsung Side by Side Refridgerator RS21 FCNS which has stopped cooling the fridge - the temp sticks on about 14deg. Yellow pages engineer came out and quoted a ghastly job and £350.
Called Samsung on 0845 726 7864 and they told me that the defrost heater is a design fault and that warranty on this component has been extended to 5 years. Someone coming tomorrow to fix it (for free).
Apr 21, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
