Question about Canon Office Equipment & Supplies
Error 1222 could not connect to scanner
When trying to download the assistant app for Android I receive this error ?
Go to settings >application > Play Store >Clear Data & Clear Cache.
Go to accounts >Google >Remove account.
Reboot device.
Details here :
http://wikitechsolutions.com/1222/error-while-retrieving-information-from-server-rpc-s-3-aec-and-rpc-7-aec-0
Apr 16, 2016 | Android Cell Phones
Tip
How to connect barcode scanner to your pc
In order for them to be useful, barcode scanners often have to be connected to computers. We will recall that in virtually all cases, the data which gives meaning to the barcodes they read is stored in databases, which are in turn hosted on computers. What the barcode scanners are meant to do, then, is to transmit the data they scan to the computer, with the computer checking that data against the database in order to assign meaning to it. In most cases, then, scanners without computers will tend to be quite useless. For a scanner to be useful, it has to be connected to the computer. And what we are interested in, for this discussion, is gaining an understanding of the ways through which barcode scanners connect to computers (at the simple, physical, external level).
As it turns out, there are four main ways through which barcode scanners connect to the computers which host the databases upon which they depend:
1. Serial port connection: this is where the scanner comes with a pin which you simply hook onto the serial port of your computer (like where you would hook an extra mouse), and thence connect the barcode scanner to computer. It was, arguably, the first method for connecting barcode scanners to computers to be developed. Its disadvantage is that it is not a plug and play approach. You have to go through quite a lengthy installation process for the barcode scanner, when you go this way. Furthermore, should the scanner 'hang' somewhere in the middle of a computing session, you don't have the option of just unplugging it and then plugging it in again to see whether it will work. Instead, you have to restart the whole machine again, and this can be very disruptive, for instance in the midst of a shopping checkout for a hurried customer. In this system, a scanner would also need specialized software to connect to various computers, meaning that there was no universality in scanner usage.
2. Keyboard wedge connection: this is a connection method where the barcode scanners are put in somewhere between the keyboard and the computer as a 'wedge.' It is something of an improvement on the serial port connection.
3. USB connection: this is what is to be found on most scanners, today. It is where you connect the scanner to the computer using any USB port. A scanner made in this way can, therefore, be used with pretty much any computer. Should it stall midcourse, you have the opportunity to just unplug it, and plug it again, to see if that solves the problem (which it often does). It is also convenient, because in this approach, connecting the scanner to the computer becomes as easy as connecting a USB flash disk to the machine.
4. Wireless connection: this is the emerging technology in ultra-modern scanners, where using systems such as Bluetooth, they are able to connect to the associated databases wirelessly.
on Oct 05, 2010 | Computers & Internet
How do I get the scanner to work on my computer
your printer probably has a software to install.
this software has the mode to scanner and to scan. the pc has a printer connection right? and.... how to scan should be on the software for the printer. it recognizes the printer and it's looking for a scanner, this is why is telling you scanner connection under the scanner connections but if the use is with the printer as a scanner, it must've a software. maybe the printer a scanner button so the pc recognizes it as scanner.
Jan 22, 2015 | Office Equipment & Supplies
I tried to connect my Canoscan lide 90: when I try to scan: my computer doesn t seem to connect to the scanner: try the cable, connection and turn the scanner on. The connections seem to work... how do I...
Hi ,
The driver is probably missing . You can download and install it from here :http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_lide90#DriversAndSoftware
Best regards .
Aug 04, 2014 | Canon CanoScan LiDE 90 Flatbed Scanner
Can't find scanner
Is the scanner visible in Device Manager? If not you have a hardware or connection issue.
Is the connection USB or network? If network have you checked TCP/IP settings? If USB are the USB items OK in Device manager?
Is it an old scanner connected to a new Windows version such as Win7. Some old scanners are not compatible.
Jan 11, 2014 | Microtek ScanMaker 9800XL Flatbed Scanner
Are there any drivers for the ibm infoprint 1222 for windows 8?
for now, i don't think its available.but wait some time and it may come out:)
Nov 27, 2012 | IBM Infoprint 1222 Laser Printer
What leads to connect scanjet 5470c scanner
First, a power adapter is required to connect your scanner. the power adapter must be supplied with the scanner. If your scanjet 5470c scanner is having USB interface or connectivity, then you need USB cable and if it is SCSI interface, then you need SCSi cable to connect to your PC. The cables are usually be supplied with the scanner. If lost, you may have purchase teh same. For further assistance, please visit the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=15179&prodSeriesId=28456&taskId=115
Hope the above information is helpful.
Thanks,
ScanCare
Jun 25, 2012 | HP Office Equipment & Supplies
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
ScanAllPro starts, chose the scanner shows the error: scanner is not connected or another application is using it. but no application is used at this moment. and the test with document scanning by...
Hi,Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.Specify which driver is used for the scanner, the TWAIN or ISIS/VRS driver. When a scanner is no longer connected to a USB port to which it was previously connected, this option checks if any scanner of the same model has been connected to the other USB port. If the same model is found there, this option automatically switches to the other port and inherits the settings of the same model.
* This option will not be available, however, if a different model has been connected to the port where the scanner was previously connected. * Disable the settings when you want to connect more than one scanner of the same model to your computer.
Thanks,
ScanCare
Jun 24, 2011 | Fujitsu fi-5120C
20 people viewed this question
old marine
old marine
