Question about Panasonic RX-ED707 Boombox
Speakers are out
Boom box will power up and all component seem to be working but speakers are not putting out sound.
Ue boom connected to pc but is not playing music... if i get lucky i get muffled sounds play back, how do i fix this
Q: What should I do if the audio is distorted or drops out on my UE BOOM?
A: Audio distorted or dropping out when streaming to UE BOOM
If you're having trouble with audio distortion or drop-outs on your UE BOOM, try these suggestions:
  • Move the audio source closer - it might be out of the range of your speaker.
  • Move away from other sources of wireless signal - you could be experiencing interference.
  • Make sure your speaker has enough battery power (connect it to a power source with the supplied adapter).
  • Adjust the volume on both the audio source and your speaker.
  • Restart both your speaker and the audio source.
  • Re-pair your device with your speaker (see, "How do I pair additional Bluetooth® devices with my speaker?").
  • If you're using two UE BOOM speakers (for Double Up), try disconnecting and streaming to one speaker only.
NOTE: If you're streaming audio content from the internet, the issue could be with the internet connection and not your speaker.
Dec 26, 2014 | Microsoft Computers & Internet
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
Boom audio, blown fuse
Fill the air with sound from this Boom!™ Audio Boom Bagger Kit. This complete audio kit provides the latest in Harley-Davidson® audio components. When installed, the increased power of the amplifier provides the speakers with a clean signal, and a custom equalization is available to further optimize the performance of the Boom!™ Audio speaker system.
  • 4-Speaker Ultra Boom!™ Bagger Kit
  • Ensure maximum output of your audio system with the recommended High Output Charging System P/N 29900028
  • Dealer Digital Technician software update is required
  • Dealer installation is recommended
  • Kit includes Boom!™ Audio 6.5" fairing speakers, Boom!™ Audio 4-channel fairing-mounted amplifier, amplifier mount and wiring harness
  • Speakers feature two-year warranty
  • Stop by a participating dealer to interact with a unique audio display that lets you simulate how your bike will sound with Boom!™ Audio upgrades. Contact your local dealer for details
From: http://www.harley-davidson.com/store/boom!-audio-boom-bagger-amp---speaker-kit-pa-08-76000411--1
Jun 11, 2012 | Harley Davidson Motorcycles
My MTX JH600 works intermittently. I don't hear the fans coming on at all and the amp doesn't seem to get hot. Even at low power the amp will turn off all of a sudden and then boom back on after...
One of my friends had a amp like that , i looked at it an the inside of speaker box wires was touching , if thats not it then check ur power an ground , power wire must be the same size ground an if ur ground is not grounded good then u will get the cuting out .
Jun 10, 2011 | MTX JackHammer JH600 Car Audio Amplifier
I need to add outdoor speakers,and the headphone
I would run the headphone jack to an amp then hook up you outdoor speakers to the amp.
Oct 07, 2009 | Sirius SUBX1 Universal Plug and Play Boom...
No sound on a Sharp 37" Aquos TV
Try the main resets in the back by the a/v in and out jacks. If this does not work, call Sharp Customer Service and tell them that you already did the resets. There is a known problem with a heat dissipation pad and they will send a repair tech to replace the pad for free, even if you are out of warranty.
Jul 08, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
The sound goes off intermittently
Forget Sharp's defective speakers. Connect your sound output to powered stereo speakers and disable the internal speakers (look through the TV's menu). The operator's manual explains how to disable the internal speakers. You'll be able to control the sound normally (mute, volume) with a remote control.
I connected my stereo output (2 RCA plugs) to an old boom-box and I get better sound than with Sharp's built-in speakers.
Jun 28, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Magnavox 9p6444c102
I had the exact same problem with my Magnavox TV. No sound and no video but the power light was lit.  You can find the solution here.
http://www.magnavoxhelp.com
May 27, 2008 | Philips Magnavox 9P6034C 60" Rear...
Sound device
First has this ever worked?
If yes - Please verify that you have power going to your speakers (if power is needed) and that you are plugged into the correct port on the computer (usually green that says sound or line out)
You may want to test your speakers on other types of equiptment, such as a boom box or anything for that matter that supports the plug.
You may also want to try the computer with a different set of speakers.
If this works replace your speakers if not I would ask you what type of operating system do you run on your computer such as windows xp, '98, Vista ?
Oct 21, 2007 | HP Sound Card
Panasonic RX-ED707 Boombox Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
