Question about Crafts & Hobbies
Remove glue c
Hot glue on fabris
How to reattach headliner trim around driver side window opening on 2001 vw beetle
You are better off just peeling off the fabris and painting the liner with a flat paint. That is what I did. I tried to spray glue it and it just kept peeling back off.
Feb 28, 2015 | 2001 Volkswagen Beetle
How to use glue gun
PLug it in and if there is a on/off swith turn it on. The gun's heating element will get hot. When it is hot enough to melt the glue stick you have put inside through the hole (that is glue stick sized and on your end) then the trigger will push the glue stcik into the hot metal melting and coming out the end so you can deliver it where you want to glue something. Beware of the heat. You absolutely can burn yourself touching the hot parts of the glue gun. Think how you would not touch the hot part of a steam iron... same problem.) That's pretty much it. Pull the trigger to push the glue stick though and add more sticks as you need them. And beware of the very hot nature of hte tool.
Dec 27, 2013 | Stanley Crafts & Hobbies
HOW TO REMOVE CRAZY GLUE FORM ARBORITE
I would try either:
a) a razor blade and hot soapy water
b) acetone (nail polish remover)
c) if there is alot of it and neither of the previous 2 solutions worked, you can buy superglue solvent
Dec 14, 2012 | Elmer's Instant Krazy Glue
What is wood glue sticks
Wood glue sticks are hot glue sticks which are specifically designed for use with wood (such as for glueing together a birdhouse).
Sep 25, 2010 | 3M Polygun AE II Hot Melt Glue Gun
Glue stick is stuck in glue gun and can't be removed.
Make sure you plug in the gun so glue is soft if gun not getting hot the you have another problem
Sep 29, 2009 | 3M Crafts & Hobbies
I am having difficulty glueing PVC together. I
3M Hot Melt 3764 is the correct adhesive for PVC.
Apr 22, 2009 | 3M Polygun AE II Hot Melt Glue Gun
NO FABRIC SOFTNER
The fabris dipencer hose was clug need to remove hose , clean w/ stick not so tight rinse w/ water then assemble .
Jan 09, 2008 | Kenmore 43142 Front Load Washer
Crafts & Hobbies Logo
75 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
