Question about HP Compaq Presario V5210US Notebook
Nee replacement hard drive hatch cover for
Need hatch cover & 4 screws
    New Friend:
Cp11 20908 j 065254
Posted on Mar 30, 2014
I need instructions for a janoel 12 egg incubator please i have lost mine
Here are instructions from another website along with various links to download manuals and lead you to other forums talking about egg incubators:
Operating steps:
1. Put the mesh with the rail(big mesh)(fig.1) into the incubator.
2. Put the moveable egg tray (fig.2) on the mesh with rail, please do it within the rail.
3. Put the egg tray grille ( fig.3) into moveable egg tray according to size of egg for incubation.
4. Put the hatching egg into moveable egg tray(fig.5) for incubation, pay attention that after each egg is put into the grille, there should be 5mm clearance at least for convenient turning of hatching egg, inject 100ml water into the base after the hatching egg is put, check once for every two days so that the incubator is not short of water. Every water injection shall not be more than 100ml, take down the date of placing hatching egg so as to well control the hatching time. It's best to place the incubator on 60-100cm for convenient insertion of link rod.
5. When closing the cover(fig.7) , the link rod must insert the shifting slot of moveable egg tray, so that the egg tray can shift normally.( in other words, the cercley thingy coming out of the top with a rod in it has to be attached to the egg tray by putting the rod into the egg turner square hole to make sure that the incubator turns the eggs well)
6. Switch on the power supply after closing the cover, and set temperature according to push-button instruction and incubation technology. If the user has no time to care about the temperature, the temperature can be set at 38'c from the first day of hatching, and it can be set as 37.5 - 37.8C since the following day of hatching.
7. It moves to hatching tray 3 days earlier than incubation period for other poultry
8. It usually takes 3-4 days less than the number of incubation days for egg tray replacement, replace the egg tray once one or two hatching eggs are seen hatched, take all of the hatching eggs off from the incubator firstly, then take the moveable egg tray with mesh with rail out, check the water level, then put the hatching mesh( fig. 10) and egg tray in and put the hatching egg on the egg tray, shown as fig. 11.
9. After closing the cover and switching on the power supply, the hatching situation can be observed.
This was originally posted here: Janoel 12 incubator help
Best wishes,
Joe
Aug 25, 2016 | Hard Computers & Internet
Tip
Install a new hatch on your boat
Replacing old and damaged hatches on your boat is not a difficult or time consuming task. You will only need a few tools to replace the hatch. You will need some starboard (poly-sheets), screws, hinges, a drill, a saw, a screw driver, sealant and a sander.
Using the old hatch cover as a guide draw an outline on the starboard for your new hatch cover. Then using a saw and a guide cut out the hatch covers and sand the corners down so they aren't sharp and to round the edges all the way around.
If you need to add a finger hole to lift the hatch, measure and mark the place where you want to add the hole. Using a hole saw drill out the hole and sand out the inside and edges to make sure there are no sharp or jutting edges.
Go to the boat and using epoxy or an equivalent sealant to fill the old screw holes. Wait for the sealant to cure before moving on to the next step.
Lay the hatch cover over the hole on the boat and align the hinge and draw in where the screws go. Take your drill and make a hole for the screws to go in. fill the holes with sealant and screw the screws into the holes through the hinge. If there is any sealant overflow wipe it up carefully with a cloth. On the other side of the hinge repeat the previous steps being careful not to drill all the way through.
Once you have attached both of the hinges you are all ready to go!
Happy sailing!
on Feb 24, 2014 | Building Materials
Need to take cover off a HP all in one computer that has lock. Need to replace hard drive. How do I get if off?
I never knew a computer came in All-In-One's. That's for Multifunction Printers. Anyway, if you're asking how to get to the hard drive it's simple.
If you're talking about a desktop, then you simply remove the outer case usually secured by 4 or less screws. Then you can remove the hard drive which might have screws or some type of bracket holding it in place.
If you're talking about a laptop in most cases you simply turn the laptop over and on the bottom look for a cover that has 3 or 4 circular disks on it. That's the hard drive. Remove the screws that is holding the cover, then you will see the drive. The drive might be secured by screws also and it might be inside of what is called a caddy which has screws. Remove all screws to get the drive.
Mar 15, 2012 | HP Computers & Internet
How do i remove Hard Drive from my Acer Aspire Note Book Model 5742Z Taken one screw out of carrier for HARD drive still cannot remove drive &carrier help Ken Leatham
I found this online, so hopefully it helps. It's to a page selling a second hard drive caddy for the 3623WXCi, but at the bottom is has directions on replacing the hard drive for that model as well.
http://www.batterystyle.com/acer-aspire-3623wxci-caddy-p-413622.html
Sep 06, 2011 | Acer Aspire 3623WXCi Notebook
2003 sienna tail light need replacing. How do I gain access to replace lightbulb. There is a nut on the hatch, do I reomove the nut and the light assembly come out? Help if you can, thanks,
If the 2003 is like my 2002 Sienna and you are trying to replace the light within the hatch, then you have to access this light assembly through the rear interior panel. You can not remove the lens or the light assembly from the exterior of the vehicle. This really did take about 10 minutes.
Step 1 - remove the 2 screws from the hatch back handle by flipping the covers down to access the screws. Insert a screw driver about 1/16 of an inch into the top of each end of the handle to flip the covers down. This will expose the screws.
Step 2 - Use a socket drive wrench to remove the 10 mm screw from each end of the handle.
Step 3 - Use a screw driver to slide the cover up and off of the retaining clip on the left (drivers) side of the rear panel and remove the 10 mm screw from the clip.
Step 4 - Now the only thing holding the back interior panel on is about nine plastic clips. Carefully pull the panel away from the door starting at the bottom where the handle was removed. Work your way across the bottom and up the left side popping each of the snaps loose. Move back to the right and in my case the panel fell off in my hands. I was able to remove and replace the light with ease at this point.
Apr 30, 2011 | 2003 Toyota Sienna
I want to upgrade the hard drive on my acer aspire L100. How can I find a manual to do this.
open the cover on the bottom....
2. take the screw out that is holding it in...
3. pll out hard drive (HDD)
4. remove 4 screws on side of HDD
5. put caddy on nee HDD.
6. insert new HDD and put the screw back in where it was....
7. install operating system
8. there you go ..... u did it
Feb 15, 2011 | Acer Aspire L100 PC Desktop
I need to replace the optical drive in a compaq presario c300nr laptop. How do I get to the drive?
Hi.
The hard drive cover is located at the base of the computer. To replace the hard drive:
1. Prepare the computer for disassembly, turn it off, disconnect power adapter and remove main battery.
2. Loosen the two Phillips PM2.5×5.0 captive screws that secure the hard drive cover to the computer.(see pic.1)
3. Lift the rear edge of the hard drive cover , and then swing it up and forward and remove it.
4. Slide the hard drive to the right, and then lift the hard drive from the hard drive bay.(pic 2)
5. Do operations in reverse order to install the new hard drive.
Pic1:
Pic 2
Regards.
Ginko.
Nov 17, 2010 | Computers & Internet
How to replace tail light
First you need to lift the hatch. There are two screws under plastic caps. Remove the caps and you will be able to unscrew these screws. Carefully using a flat screw driver to pry out the tail light assembly. It have to plastic pin that attached to the car body. do not break the pin. After you pry out the tail light assembly, you will be able to replace the light bulb. Replace everything in a reverse order.
Nov 17, 2008 | 1999 Lexus RX 300
Hard drive replacement
Can only find one manual for this machine and the download is only compatible with Windows ME. The hard drive is located in the front left hand corner of the machine. Look at the front for a retangular panel, held by two screws, that slides out. Also, with some of the older Toshibas to acess the drive, you had to remove the plastic that surrounds the keyboard, holding the mouse buttons.
Jul 22, 2008 | Toshiba Satellite 1715XCDS Cooling Fan...
Dell Inspiron 1000 Disassembly
The teardown information from rbrown67 was very accurate and easy to follow. It helped tremendously in tearing down my machine to replace the AC plug.
Mar 14, 2008 | Dell Inspiron 1000 Notebook
HP Compaq Presario V5210US Notebook Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
