Question about Parrot Zik by Starck
Parrot zik headphones fully charged but won't turn on
Won't work unless plugged in - not the ideal situation for wireless headphones
How to charge a wireless headphone called by-bo-101?
normally those headsets are charged via Micro-USB i would think....im not fully sure unless you have a photo of the headset
Dec 05, 2016 | Audio Players & Recorders
6I can't get the parrot to pair with my new iphone
turn on bluretooth then delete all pairings then turn on headphones and use phone to search for new devices
May 30, 2015 | Parrot Blue B250xt Bluetooth Wireless...
I want to listen to my television through headphones as i am hard of hearing and i want my husband to be able to hear it at his level. I have bought Panasonic wireless sourcing sound headphones RP-WF
That is a good ideal Lynda. I have no experience with those headphones so my ideas/troubleshooting is just general. Can you try them on another device? Are you sure you have them plugged into the correct jack on the TV? Are the headphones and adapter fully charged or have fresh batteries? There is the possibility that they are defective. I also use a set of headphones from my TV - iLuv bluetooth headphones. I use them when I am on the treadmill.
Jan 08, 2015 | Panasonic Televison & Video
Connect headphones to tv
It sounds like you have wireless headphones so maybe its not tv maybe more like transmitter signal between headphones and reciever so hopefully you have a way to test siganal. However the default headphone jack on TV should work fine unless turned off in audio settings in TV. Hope some of this helps you.
Apr 15, 2014 | Panasonic Audio Players & Recorders
Charging problem?
The battery in the headphones is most likely not taking a charge anymore and will need to be replaced with an equal value rechargeable battery
Jan 04, 2014 | TekNmotion Airhead 1000 Wireless...
Battery is fully charged, but netbook won't turn on unless plugged in.
I would say that you definitely need to purchase a new netbook battery. If it's only turning on when plugged in, then the battery itself doesn't have any more charge cycles.
Oct 10, 2011 | HP Mini 1033CL Netbook
My headset is fully charged but won't turn on
Hi denaschumake,
this may be due to the device being " Over charged " meaning the device has been charged for too long. i suggest for you to take your device to the store you bought it along with the receipt so the issue can be fixed.
i hope this helps.
May 16, 2011 | Motorola Mobility S9 Headphones
My unit won't turn off.
I have a Remington electric razor fully charged and it won;t shut off unless I plug it iin. When I remove the plug in cord it runs all the time?
Dec 14, 2009 | Remington MS5500 Electric Shaver
Logitech Freepulse headphones won't turn on
There is a reset button on both the headphone and the transmitter. Try to reset them both before attempting to pair them again. Since the led won't turn on there is a possibility that the battery is not charging. Is the orange light working when the headphones are charging? It should be and then it should turn off when the battery is full.
Nov 25, 2008 | Logitech FreePulse Wireless Consumer...
Headphones change batteries
Any luck with that model number??
Apr 06, 2008 | Radio Communications
Parrot Zik by Starck Logo
106 people viewed this question
Top Parrot Radio Communications Experts
Henry  Thomas
Henry Thomas
yobo007
yobo007
Are you a Parrot Radio Communication Expert? Answer questions, earn points and help others
