Question about Saeco Royal Professional Espresso Machine
DREDGE DRAWAR FULL SIGNE COMES UP. EVEN AFTER EMPTYING DREDGE DRAWER MACHINE WILL NOT RESET TO PRODUCT READY
  • 1,089 Answers
Hi When you empty the dredge drawer, the machine must be on and in use. Take the dredge drawer out and leave it out for 15 seconds. If the machine is off when you empty it doesn't know that.
Posted on Jun 15, 2009
After emptying the dredge drawer and replacing it, the unit still says "Dredgedrawer Missing"
The sensor that detects the presence of dredge drawer is not closing. Locate it and fix it or just jump the wiring to the sensor.
Aug 09, 2015 | Saeco Magic Comfort Plus Espresso Machine
'dregdrawer full' message but not disappearing when emptying it
HI Are you leaving the machine on when you empty the dredge drawer? There has to be power for the computer to see that the dredge drawer has been removed. Leave it out at least 15 seconds, so the computer thinks you emptied it. This should clear the message.
Jul 09, 2011 | Saeco Incanto Classic Espresso Machine
Gaggia Digital Syncrony dredge drawer error won't
Hi
Do you still have the tab on the left side of the dredge drawer? If you do, you can loosen the 2 screw just above the slot wherer you put the credit card. Push down on the plastic ramp in the slot as far as you can, then holding the ramp down tighten the 2 screws. If you don't have the tab you will need a new dredge drawer. Also on some machines the drip tray will lift the dredge drawer and it will give this message. There is a extra piece of plastic in the 90 deg. notch that can be trimed out to stop it from lifting the dredge drawer.
May 14, 2011 | Gaggia Syncrony Compact Digital Espresso...
Machine shows message 'dregdrawer full' even thought the dreg drawer is empty. cant get rid of this error message.
Hi
When you go to empty the dredge drawer you must leave the machine on. When you remove the dredge drawer it will say dredge drawer missing. Leave it out at least 15 seconds so the machine knows you are empting it. When you insert it again the machine will count about 24 cycles and tell you to empty it again. Its a counter.
May 12, 2011 | Gaggia Syncrony Compact Digital Espresso...
Flashing beans/dregs light -- can't start machine.
Hi
Either you dredge drawer is missing.
The tab in the back of the dredge drawer is broken.
The microswitch is bad for the dredge drawer.
The grinder motor is bad.
Apr 23, 2011 | Saeco Incanto Classic Espresso Machine
Gaggia titanium machine, display says dregdrawer missing, even when I've clicked drawer back in place after cleaning it...
Hi
Either your tab is broken on the back of your dredge drawer or your microswitch has been moved from its correct position. There should be a tab on the back of the dredge drawer. If not you need a new dredge drawer.
Sep 13, 2010 | Gaggia Titanium Espresso Machine
I have emptied the dregs drawer, after prompting, and I keep getting a message saying firstly that the dreg drawer is missing (It isn't and I have checked that has been properly fitted)and then that the...
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
When you want to empty the grounds because it says to in the menu, REMEMBER TO LEAVE THE MACHINE ON when you remove the drawer. The machine is a counter and when it reaches the magic number for that machine the message comes on. If the machine is turned off when you pull the drawer out, the machine doesn’t know this and the message will be there when you turn the machine back on. Also remember to leave the drawer out for at least 15 seconds or a little longer so the machine thinks you actually dumped the grounds
Dec 29, 2009 | Gaggia Syncrony Espresso Machine
My Saeco magic grinds the beans, but no coffee comes out. Sometimes it makes one cup, and skips. Other times, I grind the equivalent of 8 cups of coffee without any cups of coffee coming out.
HI
When a machine grinds but doesn't make any coffee there are a couple of things.
If the grounds are wet in the dredge drawer, then you have a plugged brew head and need to clean it.
If the grounds are dumped dry into the dredge drawer, then you have an overcharge and need to adjust the dosing lever back from the full charge. On your machine it is inside the door at the top center. Pull the lever back towards the front 1 click. Then try again.
Nov 14, 2009 | Saeco Magic De Luxe Espresso Machine
Dredge drawer full and it is empty
Hi
One thing you want to make sure you do is leave the machine on when you remove the drege drawer other wise the machine doesn't know that you emptied it. Remove the drip tray and pull the empty drawer out about half way and leave out for 15 seconds. Then push the drawer back in from the right front side with 1 finger. That way you make sure that you engage the switches in the machine. If you slam the drawer in you can pull it away from the switch and it will say drege drawer missing. If you put the drip tray back in, it can sometimes lift the drege drawer and disengage the switch. There is a notch in the right side of the drip tray that has a flashing on the back side of it. You can remove about an 1" of the right side of the flashing and it will stop the lifting of the drege drawer. Remember to leave the machine on when you empty the drege drawer other wise it doesn't know.
Jul 17, 2009 | Saeco Royal Professional Espresso Machine
DregDrawer full message won't clear
When you need to empty the grounds draw remove the drip tray and pull out the dregs draw - don't open the side panel or turn off the machine, - It works for me!!
Feb 20, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
352 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
