Question about Sony SNC-RZ30N Network Camera
Java security
On certain programs receiving message security risk for java my java is up to date
Java upgrade as changed the security status and some websites do not like it. You might need t downgrade the security on the browser in order to run Java scripts.
Read the notes on Java.com.
Feb 09, 2015 | Computers & Internet
Says i don't have java
What browser are you using? Due to some security issues, some browsers will disable the Java plug-in. This is often the case for older versions of Java. Check java.com for patches.
Check if the plug-in is enabled. In Internet Explorer, click on the Gear in the menu bar and select Manage Add-ons (scroll down to check the Java plug-in). In Firefox, go to Tools > Add-ons. Then go to the Plug-ins section. For Chrome, navigate to chrome://plugins.
If you see that Java is disabled, click on Enable and then restart the browser.
I hope this helps.
(due to the security issues with Java, you should only have one browser with the plug-in enabled. Do most of your web activities in a browser with Java disabled.)
Mar 20, 2013 | Pogo.com Video Game Consoles & Games
Theres a way to install java applications bigger than 700kb on samsung chat335?
Try one of the following code! (Depending on your Firmware) * # 6984125 * #, then select Internal, enter the security code * # 9072641 * # Continue to select Storage Settings, select the Update Java DB * # 5239870 * #, then select Internal, enter the security code * # 7092463 * # Continue to select Storage Settings, select the Update Java DB for the machine was up tick patch and select "EasyAdminMenu" : * # 3333 # then select Internal, enter the security code is 1111 Continuing select Storage Settings, select Update Java DB
Oct 31, 2011 | Samsung Cell Phones
What is J2ME?
J2ME
Java Platform, Micro Edition (Java ME) provides a robust, flexible environment for applications running on mobile and other embedded devices—mobile phones, personal digital assistants (PDAs), TV set-top boxes, and printers. Java ME includes flexible user interfaces, robust security, built-in network protocols, and support for networked and offline applications that can be downloaded dynamically. Applications based on Java ME are portable across many devices, yet leverage each device's native capabilities.
Java Security
Java security technology includes a large set of APIs, tools, and implementations of commonly used security algorithms, mechanisms, and protocols. The Java security APIs span a wide range of areas, including cryptography, public key infrastructure, secure communication, authentication, and access control. Java security technology provides the developer with a comprehensive security framework for writing applications, and also provides the user or administrator with a set of tools to securely manage applications.
Jul 17, 2010 | Sun Java Studio Standard 5 (SSJI9501TL9M)...
My Java stopped working when I took Norton's out and I can not get it working again. I have taken it out and put it back in several times and still it want work, it says it is working, but when I go to a...
First please go here and check whether its functioning well. Sun Java Site If it doesn't work follow the steps.
Get latest updated one from here http://www.java.com/en/download/manual.jsp
This problem happens when Norton Internet Security or Norton Personal Firewall has been configured to block scripts, ActiveX controls, Java applets, referral information, or advertisements.
ActiveX controls and Java applets can be blocked by customizing your security settings from the main interface. To find out whether this is the problem, read the section "Customize security settings."
All of these security features (scripts, ActiveX controls, Java applets, referral information, and advertisements) can be blocked by specific Web rules. These rules are located in the Advanced Options of the program. For scripts, ActiveX controls, Java applets, and referral information, see the "Web rules" section of this document.
You have to configure the settings of your antivirus suite or/and firewall. Since I do not know which version of Norton you use (if you provided the version I could guide you further. Even if you have uninstalled the settings would be there. How to enable Java if disabled... http://www.java.com/en/download/help/enable_browser.xml
This answer is aimed at Java Runtime and Plugins in a Windows environment. Not aimed at any other operating system including Java Desk.
May 29, 2010 | Sun Java Desktop System
When downloading from the internet i get a message saying your java is not switched on.where in my menu set up can i activate it
Internet Explorer 8 Windows
  1. Click "Tools" in the menu bar, and then select "Internet Options".
  2. Click the "Security" tab. For the Internet zone, be sure that the Security level is set to "Medium" or below. (If you have chosen to customize your security settings for the Internet zone, be sure that under the Java heading, "Java permissions" is not set to "Disable Java." You will want to select one of the three safety levels instead. Also be sure that under the Scripting heading, "Scripting of Java Applets" is set to "Enable" or "Prompt.")
  3. Next, click the "Advanced" tab.
  4. Scroll down until you see the sub heading "Java"
  5. Check the boxes next to "Java JRE"
Firefox 3.5 for Windows
  1. Click "Tools" in the menu bar, and then select "Options".
  2. Click on "Content".
  3. Put checks in the boxes next to "Enable Java" and "Enable Javascript".
Dec 09, 2009 | Office Equipment & Supplies
The yahoo games is not loading the applet why is that
JavaScript are fully enabled in your browser. Follow the steps below for your browser:
Netscape 4.XX or newer for Windows, Mac, or Linux
Click "Edit" in the menu bar, and then select "Preferences."
Click the word "Advanced" and put checks in the boxes next to "Enable Java" and "Enable JavaScript."
Internet Explorer 4.XX for Windows
Click "View" in the menu bar, and then select "Internet Options."
For the Internet Zone, be sure that the Security level is set to "Medium" or below. (If you 've chosen to customize your Security settings for the Internet zone, be sure that under the Java heading, "Java permissions" is not set to "Disable Java." You'll want to select one of the three safety levels instead. Also be sure that under the Scripting heading, "Scripting of Java Applets" is set to "Enable" or "Prompt.")
Scroll down until you see the subheading "Java VM."
Check the boxes next to "Java logging enabled" and "Java console enabled." (Note: If you've checked the box next to "Java JIT compiler enabled" and are experiencing freezing problems, uncheck that box.)
Internet Explorer 5.XX or 6.XX for Windows
Click "Tools" in the menu bar, and then select "Internet Options."
Click the "Security" tab. For the Internet zone, be sure that the Security level is set to "Medium" or below. (If you've chosen to customize your security settings for the Internet zone, be sure that under the Java heading, "Java permissions" is not set to "Disable Java." You'll want to select one of the three safety levels instead. Also be sure that under the Scripting heading, "Scripting of Java Applets" is set to "Enable" or "Prompt.")
Check the boxes next to "Java logging enabled" and "Java console enabled." (Note: If you checked the box next to "Java JIT compiler enabled" and are experiencing freezing problems, uncheck that box.)
Note to Windows XP users
By default, the Windows XP operating system comes with the Internet Explorer 6 browser without the Java Virtual Machine (JVM) installed, which is required to run Java programs such as Yahoo! Games.
If you install Windows XP over an existing installation of Windows that already has Internet Explorer with a JVM installed, then you should be able to play just fine.
At this time, Microsoft no longer provides a download of the JVM if you do not already have it installed. You're welcome to contact them for information on where to find and download this program.
However, you have the option to download Sun's Java plug-in by visiting
http://www.java.com/en/download/help/aut…
Sun is the creator of Java, and their plug-in will allow you to play Yahoo! Games.
Internet Explorer 4.5 or 5 for Macintosh OS 8-9
Select "Edit" from your menu bar and choose "Preferences..."
Then, click the "Java" bullet within the Web Browser section.
Make sure that the "Enable Java" box is checked.
Internet Explorer 5 for Macintosh OS X
Select "Preferences" from the "Explorer" menu.
Select "Java" from the left navigation bar.
Place a check-mark next to "Enable Java."
You may also want to clear your cache and restart your browser.
If you continue to have problems, double-check your computer's compatibility with Yahoo! Games. Source(s): Yahoo games help page
Oct 19, 2009 | Yahoo Mail
Cant get into yahoo canasta
Try clearing out your browser cache first.
Double-check that Java and JavaScript are fully enabled in your browser:
Scroll down until you see the sub heading "Java VM."
Mar 14, 2009 | Computers & Internet
Type of JAVA
java.applet(PersonalJava only), java.awt and sub-packages, java.beansjava, iojava.lang and sub-packages, java.lang.reflect, java.math, java.net, java.rmi and sub-packages, java.security, java.sql, java.text
Sep 15, 2005 | NEC MobilePro P300 Pocket PC
Sony SNC-RZ30N Network Camera Logo
43 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
