Question about Trimmer Mechanical Bathroom Scale with Extra Large Platform
How to change kg to lbs on a trimmer bathroom scales
My homedics mibody body manager scale will not change between lbs, stone and kg. I have tried pressing the button on the bottom of the scale however this does not work.
Probably too late, but I've just had the same problem and if you push the foot of the scale in for a couple of seconds the 'kg' display starts to flash and then you can use the button on the bottom to change to lbs.
Sep 12, 2011 | Kitchen Appliances - Others
On my "Ideaworks" wireless electronic display
After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
Aug 22, 2011 | Jobar International Ideaworks Remote Read...
Change scale from kg to lbs
Ok i Just figured it out my self with no manual. When you put new batteries in your scales the unit will be shut off. Press and hold the select button for 5 seconds and then it will show LBS or KG and you will be able to change your weight at that time. Hope this helps.
Apr 23, 2011 | Health-O-Meter Health o Meter BFM681DQ-63...
Jobar international JB5413 large cap. scale It shows in kg i want to change it to pounds.
press WT then press SET for 3 secs
then use up/down arrows to change between kg lb and st
when selected press SET again
Dec 07, 2010 | Jobar International Idea Works Wireless...
How do i chang kg to lbs
Please log on to .Eng Net tools. You an download a free software that can find great use to convert all your requirements.
 the link is as ;  http://www.engnetglobal.com/
also 1 KG= 2.20- lbs ( 2.65lbs in another system)
Please vote if helpful
Sep 02, 2010 | Conair WW73 Electronic Body Fat/Hydration...
Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Aug 25, 2009 | Health & Beauty
Need instructions on how to reset to show weight
how do I change scale from kg to pounds?
Mar 16, 2009 | Health & Beauty
Tanita, the Ultimate Scale
The scale may have instructions on the bottom of the scale. (Example for the Tanita: The Ultimate Scale w/ the body fat analysis). The instructions on the back state the following steps: Step 1: press both the "Set" and the triangle buttons. Step 2: press the "triangle" button until you select the appropriate weight measurement (a) kilogram, (b) stone lbs or (c) lbs. Step 3: press the set button.
Oct 31, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Trimmer Mechanical Bathroom Scale with Extra Large Platform Logo
125 people viewed this question
Top Trimmer Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Trimmer Health and Beauty Expert? Answer questions, earn points and help others
