Question about Sizzix Tim Holtz Vagabond Die-Cut Machine
Broke vagabond sounds like gears broke inside
Vy commodore ute is running 1st gear all the time no matter what gear the gear stick is in
sounds like shift kinkage is not installed or the yoke shifter inside is broke
Apr 20, 2016 | Cars & Trucks
Hammer drill wont drive
It sounds like the gear inside sheared the teeth. You can check with Craftsman to see if you can get a replacement gear.
Apr 07, 2014 | Craftsman Professional 1/2 in. 8.0 amp...
In gear but wont move
The opposite wheel should turn the opposite way.
Sounds like a part broke inside the trans.
Feb 18, 2014 | Chrysler Sebring Cars & Trucks
98 ram 1500 4x4 automatic transmission gear problems
please go to the webpage. www.automecanico.com translate the website with your browser , get the topic and fix it.
God bless you
Nov 27, 2013 | Cars & Trucks
Machine jammed
you must contact to the supplier manufacturer in order to get support via ONLINE chat.
GOD BLESS YOU
Nov 06, 2013 | Ellison Sizzix Tim Holtz Inspired Vagabond...
'98 chevy 2500 w/4wheeldrive will go in drive fine but won't go in reverse
if you can place gear selector to reverse and nothing happens but all other gears act normal then it sounds like the transmission needs to come out. sounds like the sun shell broke inside the trans. please let me know if I can help any more
Mar 24, 2010 | 2001 Chevrolet Silverado 1500
I have a 98 saturn sl that feels like it goes in gear but will not move its like its not ingaging no chattering or any other sound when i dont push the clutch in while its started it goes in every gear not...
sounds like the hub on the inside of the clutch disk broke free from the clutch material, thats the first place i would look seeing as how you run into it on the way down to the trans.
Nov 21, 2009 | 1998 Saturn SL
None of the gears will engage
it sounds like something broke inside the transmission
Jun 16, 2009 | Ford Ranger Cars & Trucks
Sentra will not go into first or second gear
i believe there is something broke inside the gear box which its easy to happend if u try to drive ur car without clutch .
im sorry man and good luck
Mar 21, 2009 | 1999 Nissan Sentra
Sizzix Tim Holtz Vagabond Die-Cut Machine Logo
441 people viewed this question
Top Sizzix Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Sizzix Craft and Hobby Expert? Answer questions, earn points and help others
