Question about Oster Stand Mixer model: Fpstsm5102
Beaters wont spin
When turned on beaters will not spin
Kitchenaid ksm90ww stand up mixer while mixing my aunt put in another mixing tool and it just stipped mixing wont turn on nothing I assume she blew the motor but does anyone know if theres a reset button...
It sounds like stripped gears, does the mixer still turn on? The beater just wont spin anymore?
If that is the case the worm gear probably stripped out, that is part number w10112253, or for a quicker easier fix you can get that gear in an assembly for a couple more dollars, that would be part number 240309-2.
Here is a link to those parts on our website:
http://www.mendingshed.com/kawormgear.html
http://www.mendingshed.com/kitchenaidgearassy.html
Jan 16, 2014 | Food Mixers
BEATERS DO NOT SPIN
If the beaters do not turn, the motor must be shot! In that case the problem is bigger.
Nov 10, 2013 | Sunbeam 2346 Heritage MixMaster Series...
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
The mikxer wont spinn, i think its burn up,,what can i do about it,,or should i just buy another one.
First, does the housing for the beaters spin when the beaters are not in place? If so, then there may have been a stripping of the cogs in the housing. If this the case, you definitely need to buy a new mixer. If the housing for the beaters does NOT spin period, then there is no question that you do need to buy another mixer.
Jul 14, 2011 | Rival 150 Watts MX555-W Hand Mixer
Why does my sunbean mixmaster bowl don't spin?
the spinning plate under the bowl does not have any power to spin the bowl; it only aks as a "lazy susan" carousel that allows the bowl to turn from the movement of the material being wipped in the bowl.
the beaters are purposely off-center of the bowl in ordwer to create a dragging motion of the material in the bowl, thus pulling (that is, spinning) the bowl slowly. If the beaters are not off to the side of the bowl, you will not get the pulling/spinning motion. Also, if the plate under the bowl does not move very easily, then the bowl will not spin. You may have to remove the spin plate and clean the center pivot for the plate to move freely. Good Luck, Macgivor.
Nov 27, 2010 | Sunbeam 2346 Heritage MixMaster Series...
My kitchenaid hand mixer beaters knock into each other as they spin. can i fix this?
This happened to me also, and it was because one of the beaters was no longer straight (bent just slightly, but enough). I found a replacement beater at a thrift store, and now it is fine. There were several replacement beaters at the thrift store... I'm guessing because many of the KA hand mixers are starting to die (the beaters don't 'click' in anymore).
Oct 22, 2009 | KitchenAid KHM3 Classic Hand Mixer
The beaters were clanging together. Now the
the gears were out of sync, by this time their probly stripped. IF you can get the gears, one must resemble a X and the other must resemble a + when installed, so they look like this X+ that way they wont hit.
Oct 17, 2009 | Black & Decker 220 Watts MX77...
Hobart N-50 Mixer beater attachment spins but has no resistance
Sounds like the shear pin on the planetary shaft has sheared off. Has the mixer been subjected to a heavy load. Remove the planetary and see if the shear pin is intact otherwise you may have to open up the transmission.
Ron
Jun 04, 2009 | Hobart N50 Stand Mixer
Mixer beaters clanging together
The beaters might be fixable/replaceable but the bowl not spinning anymore is the more serious of the 2 problems. If this is several years old iit probably is more cost efective/simpler to replace the whole unit.
Good luck Loringh
Nov 08, 2008 | Sunbeam Heritage 2346 Stand Mixer
Oster Stand Mixer model: Fpstsm5102 Logo
42 people viewed this question
Top Oster Food Mixers Experts
Ross Keen
paulcarew
Lawrence Oravetz
Are you an Oster Food Mixer Expert? Answer questions, earn points and help others
