Question about Honeywell Heating & Cooling
Shows will hold time and temp but never set
Will turn down the temp at night and wake up later and temp has increased would like to know how to fix this problem
3 Suggested Answers
  • 45 Answers
SOURCE: GE AGM08LJG1 window unit: digital temp increases
its telling you the room temp that is been sucked into the evaporator.its normal for this to happen.once you set the temp you want.it stays there untile you change it.but its all good.
Posted on Jun 09, 2009
  • 4736 Answers
SOURCE: I turned my thermostat down
Since it's within 2 degrees of your setting it could be one of two things. Most furnaces run longer (pass your setting) to maintain the setting you made. Which really not a problem. However, your thermostat may need calibrating. To test this theory, place a regular wall thermometer next to your furnace's thermostat and see if the two temps match when the furnace cuts on and then when it cuts off.
If the temps are both the same, the furnace thermostat is fine.
If you're turning it down to 68, because no one will be at home during the day, just set it 2 degrees cooler than 68 degrees. You will then wind up with 68 degrees.
Posted on Feb 09, 2011
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
Set alarm clock
goto http://voxrightnow.custhelp.com/app/answers/detail/a_id/12057/~/operating-the-rca-rp4803-clock-radio
or follow instruction
  1. Press the SET button until WAKE 1 / WAKE 2 icon is blinking.
  2. Press REV or FWD to set the wake time. The time decrements or increments will follow by a faster rate when you press and hold either REV or FWD.
  3. After the WAKE time is set, press SET repeatedly until no icon is blinking.
Tips:
  • The unit equips with GRADU- WAKE feature, the alarm tone volume will increase gradually to its maximum in about 30 to 45 seconds.
  • If you set the SLEEP function with low volume level before going to bed, we advise using WAKE mode to wake you up since its volume will automatically increase.
Waking by Selected Source: You may be woken up by WAKE, RADIO or CD.
  1. Select an AM or FM station.
  2. Set wake time (see above directions).
  3. Press WAKE 1 or WAKE 2 to select waking up by WAKE, RADIO or CD. Corresponding indicator will be shown next to the selected setting.
  4. Adjust the volume by turning VOL.
You can select your CD wake track by the following procedures:
  1. Make sure you have inserted a CD.
  2. While holding WAKE UP CD TRACK, press REV or FWD to select your desired CD wake up track.
Mar 18, 2011 | RCA RP4803 Clock Radio
Dont know how to set time or alarm
Press and hold the Set Wake button and the press either the fwd or rev button until the desired Wake time is reached. Release the buttons to return to the current time display. To display the wake time, press and release the Set Wake button. To turn off the alarm, press and hold Wake Mode until the alarm icon disappears. (This button lets you choose Wake to Music, Wake to Alarm or Off.)
The owner's manual is available here: http://support.radioshack.com/support_audio/37571.htm .
I hope this helps.
Mar 11, 2011 | RCA RP3711 Clock Radio
My e522b freezers alarm keeps going off all all tilmes of day and night it indicates to turn the temp up then i will do that shut the door and about 20 seconds later it tells me to turn it back down again,...
it's trying to tell you there is a defrost problem you need to have someone out to diagnose the faulty part as there are a few different parts that cause this problem the sooner the better otherwise you will wake up one day & your fridge won't be cold & you will lose all your food.
Feb 18, 2011 | Fisher and Paykel Active Smart E522B...
I turned my thermostat down this morning to 68 degrees. I came back about 2 hours later to increase the temp to 70 degrees but when I push the ^ arrow instead of showing the increase to 70 it just flashes...
Feb 09, 2011 | Heating & Cooling
I have a Trane XL900 Deluxe programmable thermostat. I has worked fine since we purchased our new home April 2011. All the sudden we have a problem with it holding the right settings at night. I have...
Try it with out the programming. There is no fix if the dates and times are correct. Before you call someone you are better off buying one online ($150) and changing yourself. Should not even have to do any wiring, just remove screen and put new one on old backplate. Of course you will have to redo all your run times with the new one. Likely pay that much for the service call just to hear you need a new one. Good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 11, 2017 | Heating & Cooling
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
shows on the display.
2. Press REV or FWD to set the clock
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
This unit allows two wake times to be set.
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
Sep 30, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Apple icon is all that comes up.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Aug 12, 2009 | Apple iPhone Smartphone
My apple iPhone display screen is completly black but the touchscreen is still working
just had same problem latest 3g phone black screen scared me waiting for important text,hold power and front button simultaneously worked as you all have been discussing ,reboots after a min, had dropped mine last week recommend getting hard back that clips on ebay five pounds n screen cover in included
apple rocks
Jul 05, 2008 | Apple iPhone 3G
Heating & Cooling Logo
32 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
