Question about Panasonic Televison & Video
Seven blinks doesnot turn on TX p42x10y
Seven blinks doesnot turn on picture is blank
2 Suggested Answers
SOURCE: Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
Posted on Sep 22, 2009
Samsung TX-P3075WH blinking red light
Hello
Check its LOT [Line Output Transformer]. Replace it along with Line Output Transistor.
Apr 07, 2012 | Samsung TX-P3075WH 30" TV
Seven red blinking led
Check the link below to find the parts that are causing the LED to blink 7 times and replace them to fix the plasma.
http://www.fixya.com/support/t5048641-easy_replace_capacitors
Jun 14, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
I have no picture and the timer/standby indicator flashes seven times. i cant find a list of the codes on the internet for what that flashing light means
seven blinks is over current protect try to turn the tv on using the sony original remote with this button sequence press display 5 volume up then power if the tv comes on replace ic8002 on the power supply if it doesn't I would still try that fix very common on sony tv's
Jan 24, 2010 | Sony KP-48S70 48" Rear Projection...
My Sony 42" DLP TV blacks out every 87 seconds. Then the green standby light blinks 30 times then I get picture and no sound. 7 more blinks after that I get sound. In 87 seconds later, it blanks out again...
Please replace Lamp in TV because this lamp is weak in result, causing darker picture and turning off and on TV.
Lamp replacement procedure would be written in user manual and its easy.
I would recommend to buy Sony original replacement lamp for TV safety.
Thanks.
Nov 13, 2009 | Sony Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sep 22, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
TV doesnot Turn ON
sounds like you need a new light bulb
May 08, 2008 | Sony XL-2100U Projector Lamp for...
Blank screen on startup on Sony KV-32FX20U
All Sony sets will stay blank until the circuit is ready to power the tube. If there is a problem detected inside the set, the tube will remain vlack and the standby light will blink. This blinking will repeat a count as follows: Blink count, pause for a second or two, repeat the blink count, etc. Some Sony sets will play for a while then flash off and on. This is usually an indication that the picture tube is starting to fail. In your case, you should see a blink code. If you can update this with the blink count, I can use that info plus the model number listed above to provide a possible cause and the parts required to repair the set.
Dan
Mar 29, 2008 | Sony KV-32FX20U 32" TV
No video - Blinking code 5
yes im a tech unknown business i cant say what business or my name could lose my job but her you go, Fix the blinking light code 5 blinks turn down your picture vivid and your contrast ive makde plent of money fixing this issue for the company.
Feb 01, 2008 | Sony KP-53HS10 TV
Televison & Video Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
