Question about Click 2 Shop Online Goophone I5 Android 4.0 Smart Phone with 4.0 inch WVGA Screen Dual SIM MTK6577 Dual Core GPSDual Cameras Black
Goophone I5S doesn't charge
It was discharging when the battery was charging
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
It has been charging for 5 hours like this and doesn't turn on. What do I do? It turned on twice but stayed at 1% for about 10 minutes but then shut off again. I have no idea why it is doing this and
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 11, 2013 | Cell Phones
Why doesn't my hp notebook charge?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 08, 2013 | HP Pavilion Computers & Internet
Will a laptop battery become damaged if you use the computer while it is plugged in? I do a lot of photo editing, and leave the computer plugged in for long periods of time, so that it doesn't di
Laptop batteries vary from laptop to laptop. i suggest you Google the Internet for a battery for your model laptop.
Oct 25, 2012 | Acer Ac Adapter Charger For Extensa...
The battery doesn't work fine
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 26, 2012 | Motorola Mobility RAZR V3
Charging problem of dell pp41L, it works as an ac online power bt it doesn't charge it.
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
May 20, 2012 | Dell Computers & Internet
Battery does not charge
Hello
Try to discharge the battery by charging it completely while off then run the computer with only battery connected until it runs out completely then switch off computer and charge it again, also make sure in
windows you are running on power save mode by clicking on the battery icon.
If that doesn't help then consider replacing the battery.
hope this helps.
Feb 20, 2012 | Computers & Internet
How to discharge battery
"Calibrating" a laptop battery is one way to increase the lifespan of a battery that doesn't last long. The procedure involves two steps: fully discharging the battery, then then fully charging it immediately thereafter. It's important to note that a full discharge doesn't mean you drain your battery until your computer powers off, but rather that you deplete it until it reaches a level of approximately 3 percent capacity, according to BatteryCare.com.
1. Charge the laptop battery to 100 percent. Allow the laptop to sit plugged-in and fully-charged for approximately two hours.
2. Click the "Battery" icon in the lower, right corner of the Windows Taskbar and click "More Power Options." Click "Change When the Computer Sleeps," then click "Change Advanced Power Settings."
3. Scroll down to "Battery" and click the "Plus Sign" icon next to it. Click "Critical Battery Level," then click the arrow to decrease the number to "3." Click "Apply," then click "OK."
4. Unplug your laptop and continue using the computer until it reaches 3 percent, at which point it hibernates automatically. Allow the computer to hibernate for at least five hours, then plug it in and allow it to recharge fully.
I hope you find it very helpful. Thank you for using fixya.
Aug 17, 2011 | eMachines eM3502074 Tablet PC
My battery was was not charged for 2 days over the weekend and now it won't run on batteries. I need to have it on AC power every time I use it.
Laptop batteries can become unchangeable if they are completely discharged, and left that way for too long. This happened to my Asus. IF you leave it charging over night and it still doesn't work you will need a new battery. If you contact the manufacture they will probably charge you over $100 for a new battery. If you use eBay, the average price is $32.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=IdeaPad+S10e+battery&_sacat=See-All-Categories
Regards, Chris
Jul 12, 2011 | Lenovo IdeaPad S10e Netbook
How can I know that the Battery Maintenance System is charging.Does the battery voltage displays on the screen??
Hai dud,
A battery maintenance system for charging, analyzing, discharging and conditioning of a NiCad battery. The system displays voltage and capacity to determine whether or not a NiCad battery has enough capacity to power equipment for an optimal time period. The system charges the battery using a negative delta voltage method of detecting full charge, while also displaying instantaneous battery voltage. The system also analyzes the battery in a charge, discharge and recharge mode of operation, and during the charge mode the instantaneous voltage is displayed. The discharge mode discharges the battery to one volt per cell while displaying voltage and accumulative capacity alternately. The system also conditions batteries by cycling a battery through three cycles of charging, discharging and a subsequent recharge cycle.
Hope it Helped You!
Aug 03, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Click 2 Shop Online Goophone I5 Android 4.0 Smart Phone with 4.0 inch WVGA Screen Dual SIM MTK6577 Dual Core GPSDual Cameras Black Logo
49 people viewed this question
Top Click 2 Shop Online Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Click 2 Shop Online Cell Phone Expert? Answer questions, earn points and help others
