Question about Refrigerators
We own an Amana bottom freezer; Mod.# BC120TW, Ser # 9708176268. It is approximately 10 - 11 years old. The freezer is not getting to a low enough temperature. We have soft ice cream etc. I have cleaned the unit bottom, condenser area, etc. It still appears to not be working properly. Do you have any suggestions before I have to call a technician? Thanks, Craig Jones North Carolina
  • 72 Answers
If it is constantly running, (compressor and the fan inside of freezer) then the thermostat is working, more than likely you have an inefficient compressor or a low charge in the sealed system due to a refrigerant leak. Touch the compressor, is it almost too hot to touch? Do you hear a buzzing and clicking noise every so often? If you can answer that for me, I could better diagnose it
Posted on Jun 15, 2009
We have a Amana BR18 Easy Reach bottom freezer. The fridge is turned up all the way, barely keeping food cold. The freezer is not freezing anything (ice, etc.). The freezer is still blowing cool air, but...
Low refrigerant assuming the compressor is always running and not being shut down by the thermostat.
You can hook up an ammeter to the unit to see if the current consumption is below spec, another sign of low gas situation since the motor is not working as hard as under normal conditions.
Jun 10, 2017 | Freezers
Amana, top single door drags when closing
I will tell you how I fixed this problem for a one time payment of $19.95. Or, go to appliancerepair.com and get the answer for free. There! That'l FIXYA.
Dec 21, 2009 | Amana Freezers
Salad in drawer is freezing
Good day,
One user claims that the return air vents or vent located at the bottom rear of the fresh food compartment, have collected enough junk to block the cold air from returning to the freezer compartment. You can clean them out but I cannot verify that solution.
The crispers are located in the coldest part of the fresh food compartment.
This problem can occur when the machine gets light usage especially in colder weather, when the machine running time drops and the air in the fresh food stratifies, causing to cold air to pool in the bottom.
Normal may no longer be normal. Controls by their design will tend to run colder as they age. You might try tweaking the control warmer.
Patience and time are the most important tool you have to work with in dealing with this issue.
Dec 04, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana energy saver not keeping fridge section cool enough. HELP!
if there is frost build up on rear wall of freezer section the unit is not going through defrost cycle which builds up frost on evaporator and restricts cold air flow to the fresh food section. one of three things are bad. defrost heater, defrost thermostat or defrost timer. if no frost on rear wall you might be low of freon.
Jun 24, 2009 | Amana ABB1927DE Bottom Freezer...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Mar 13, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
Amana Refrigerator
Dear friend,
ngfam at you service! happy to assist!
How old is the fridge ?
If its 10 years old its not worth repairing!
You will save enough money with a new fridge due to the fact that they are so much more efficient today!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 28, 2008 | Refrigerators
Bottom freezer not staying cold
One of two things. When you open the freezer drawer, do you hear a fan running? If not, that's the problem. The Evaporator fan. Its' job is to circulate cold air throughout the entire cabinet. Without it, things get toasty. If not the Evap Fan, it'll be the sealed system... meaning that it's developed a leak and freon is escaping (not harmful for you or your Family). If it's just under 5 years old, this will be a warranty repair. Over 5? Bad news... it'll cost ALOT to have it repaired.
Jul 29, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
468 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
