Question about Tefal T-fal 8322 Family Safety Fryer Cool To Touch White Deep Fryer In Box
Does the oil container come out for cleaning
I need to replace old oil. Is there a way to take out the inside oil vat for cleaniong
Auto fluid was brown so when I drained it, only 2 litres came out, so put back 2 litres of fresh which came up to the hot mark on the dipstick. Fluid now still brown ( but not as dark as before.
Michael, If your vehicle is a normal automatic transmission it will have a torque converter. If you really want to attempt a complete flush, I will post links on how it is done, you will still have to change the filter to ensure a thorough job. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Automatic Transmission FlushDo it Yourself ProceduresNO SPECIAL TOOLS OR...
Automatic Transmission Filter and Flush on Jeep Cherokee
2001 Ford F150 Transmission Service Flush Torque Converter Oil Cooler Pan...
May 18, 2016 | Cars & Trucks
I did a carburator rebuilt n now my gas went inside the oil container what to do
your float needle is either defective or you didn't clean it well enough or you didn't replace the seat... should of given us the enfine number
Sep 14, 2014 | Garden
I have miele CVA 4070 It just recently started only brewing about 1/2 to 2/3 cup of coffee or espresso and the rest of it goes into the waste container. So the waste container has a watery puck and...
Have you clean the brew unit with the cleaning tablets? This dissolves and rids the brew unit of the oils which in turn build up and clog the brew unit - the result being watery pucks and less product being disbursed.
Feb 21, 2014 | Miele Coffee System
1995 saturn! new water pump, and coolant. Changed alternator, and battery, changed oil, oil filter. noticed oily substance in overflow container. did a radiator flush, still has red, rusty color somet
Coolant is oil based. The oily mess in the overflow could be very old coolant. Or it could be engine oil from a leaking head gasket.
The rusty stuff on the floor inside the car could be from a leaking heater core.
Jul 03, 2012 | Cars & Trucks
Where is the cabin air filter located for the air conditioner?
Instructions To Replace Cabin Air Filter 2001 LS Things You'll Need
  • Pliers Screwdriver Clean damp cloth Handheld vacuum
    • 1
      Locate the cabin air filter container on your Lincoln LS. Looking at the engine from the front, you will find the casing on the left side against the back firewall. The cabin air filter is mounted vertically and is approximately 6 by 9 inches and about 2 inches deep.
    • 2
      Remove the cowling cover by pushing in the black cover pins and lightly prying the cover off with a screwdriver. Lift the filter out of the container.
    • 3
      Vacuum the inside of the container to remove any dust or debris. Wipe down the inside and outside of the container and lid with a clean damp cloth, then dry it off completely.
    • 4
      Insert the new cabin air filter into the container and check to make sure it is seated properly. Cover the container by putting the lid back on and gently pushing down to make sure the pins click into place.
Jun 02, 2011 | 2001 Lincoln LS
Where is tranny filter on 04 hyundai elantra? can a garage mech. do it? whats the best way to drain the tranny oil?
The filter would be inside the pan. The best fluid change is at an oil change place that uses t-tech style machine. This style will change the fluid in the torque converter, cooler and lines. It takes a container of new fluid and runs that in while old fluid runs out...done until clean fluid is coming out.
Apr 27, 2011 | Hyundai Elantra Cars & Trucks
What is the procedure for oil change on 2009 range rover sport,and where is the location of the Oil drain plug?
Never change your oil while the engine is hot! Let it cool for a few hours, oil can burn you badly.
Be sure you have a safe area to do your oil change. Level, solid ground is a must so that you can safely jack up your car. I also like to put something on the driveway or garage floor underneath the engine in case you spill. Cardboard or a piece of plywood are great for this.
Before you even start to do your oil change, be sure you have everything you need to get the job done.
What You'll Need
  • Ratchet or open end wrench
  • Oil filter wrench
  • Oil catch/recycle container
  • Funnel
  • New oil filter
  • New Oil
  • Clean rag
The first step in an oil change is to get the old stuff out of there. The oil drains out of the oil pan at the very bottom of your engine. The oil is held in by a drain plug that looks like a big bolt at the bottom of the pan.
Before you remove the oil drain plug, be sure that your recycling container is positioned underneath the oil drain. An oil change can be no fun if most of your time is spent cleaning up oil. When you remove the drain plug, let it drop into the top of the recycling container. There's a screen on top that will keep it from dropping into the muck.
Let all of the oil drain out, then replace the drain plug, tightening it to your cars torque specifications (or "snug but not too hard" if you are sans torque wrench.)
Put the cap on the oil recycling container so you can drop it off at a location that accepts used oil -- most full service gas stations accept it.
Next you need to remove your old oil filter. Using an oil filter wrench, turn the filter counterclockwise until it's free. Be careful with it, it's still full of old oil that can spill and make a mess. Some oil filters can be reached from the top, but for most you'll have to be under the car.
With the old oil out and the old filter out of the way, it's time to put the change in oil change. But before you install the new oil filter, you have to prep it. Before you screw the new oil filter into place, lubricate the rubber gasket on the end of the filter with some new oil. Next, fill the new oil filter with oil to about 2/3. It's ok if you go over that amount, it just means you might spill a bit when you screw it on.
Carefully screw the new oil filter into place. Remember, it has oil in it so don't forget to hold it upright. It screws on clockwise. You don't need a wrench to install the new oil filter. Screw it on as tight as you can get it with one hand. Overtightening the oil filter can strip its threads and cause a leak. Of course, not tightening it enough can cause a leak. So screw it on as tight as it will go with one hand, but no more.
Now you're ready to fill the engine with oil. Unscrew the oil fill cap and insert your funnel. I like to buy the 5-quart containers of oil (cheaper) but if you're using single quarts that's fine, too. Check your owner's manual to find out how much oil your engine holds. Pour a little more than 3/4 that amount into the engine. For example, if your car holds 4 quarts of oil, add 3 1/2.
If you're using a 5-quart container of oil, there is a guide on the side that shows how much oil you've put in.
You're not finished yet so don't drive off.
We didn't add all the oil because there may still be a little oil here and there we didn't account for. Check your oil and add more until you're at the right level.
Be sure to put your oil cap back on! Oil spray can cause a fire.
Best regards.
Oct 29, 2010 | 2009 Land Rover Range Rover Sport
How to change the oil
What You'll Need
  • Oil filter wrench
  • Funnel
  • New oil filter
  • New Oil
  • Clean rag
Best regards.
Oct 28, 2010 | 1997 Ford Taurus
When the dryer is running it smells like charcol ligher fluid
Sometime recently there has been a petroleum product used in the house. Possibly an oil based paint, stain, varnish, adhesive or some form of cleaning product.
Anyone of these products or many others like them, contain a distillate of liquid. Check around the house.
Until that oil based product dries or cures, the odor and vapors will remain and so will the dryer smell.
At the end of the drying cycle, use the air fluff cycle to purge out the smell. Besure to return the selector on the dryer back to it's prior postition.
Jun 11, 2009 | Kenmore 62882 Electric Dryer
Tried draining oil and its plugged
Hello. It sounds like you have 2 vats, correct? OK, well down where you drain the oil, the valve is usually connected to the vat with a pipe. It sounds like something is inside the vat or the pipe, so take a piece of tubing, like a copper pipe, 3/8" od should be good, bend it at one end approx. 5 inches in, and you will probably need about 3 feet of it. You are going to make a poker from it, and go inside the fry vat, where the oil is, open your drain, with a catch pan, and then poke about where the drain opening is, inside the oil area. You have a blockage of some sort, a nugget, debris, something, cloth, scrubbie stuck in there. You need to try and push it through the drain pipe and valve.
Hope this helped, and thank you.
If you need more help, " ask me".
Apr 01, 2009 | Kitchen Appliances - Others
Tefal T-fal 8322 Family Safety Fryer Cool To Touch White Deep Fryer In Box Logo
63 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
