Question about Polk Audio SurroundBar Center Speaker
AM405505808 need to know what unit this is
Trying to find my model number on my coleman q.e.d II emerson model
Your unit can be low on freezon and can have stop up inside coils if air cant move across coils it will ice up on inside clean coils and check if unit still ice up it low in freezon.
Apr 08, 2014 | Coleman Heating & Cooling
Have a heat pump mod# 13pja18ao1 r-22 unit trying to fix someone eles bad install . when i got there unit was flat they have alot of old issues with this comp won't kick in only fan even with ajump start...
Vince, that's pretty funny. If you are trying to fix a bad install on an r22 unit you're probably a little late. second, no offense, but if you don't know if it has a low pressure switch, you might not be the right guy to be fixing it. If the unit was flat it has probably had a long history of running low on refrigerant which will definitely harm the compressor. Then all the times it's been recharged who knows what's in it AND how much non condensibles are in there. Sounds like you need more than fixya!! Best Wishes!!
Oct 16, 2017 | Weather King 12AJA1801AH Air Conditioner
Would like to replace need to know size of unit and age.
this unit is a 3 1/2 unit...the 42 the model number...possible its a 89 or 97 model...this is a 42,000 btus unit...hope this helps...michael 843-384-8474..
Mar 27, 2010 | Heating & Cooling
I need to know the seer number for an air handler. I'd
On the air handler take the top panel off, look to the left on the inside, this will give you general information on the unit on a stampede plate. This will
give you the date of manufactuer as well.
On the outdoor unit, there is a stamped plate on the
condensing unit. Should have year of manufactuer, it
should also say how many pounds of freon should be
in it. The Model number is what you need to know
to find out how big it is.
024=24,000 BTU= 2ton unit
030=30,000 BTU=2 1/2ton
036=36,000 BTU=3ton
040=40,000BTU= 3 1/2ton
and so on.
My guess is that it is an older unit and since I have
been installling units since 1995 I have only known
any older units to be at least a 10 SEER and no more.
Feb 16, 2010 | Heating & Cooling
Schematic missing - need to know which cond unit
Black wire goes to contactor. On your capacitor the brown wire goes on one side the blue and the other wire from your contactor goes on the other sideof the capacitor. Russ
Aug 07, 2009 | Heating & Cooling
I need to know how to close the lines on the condenser unit.
Screw it in clockwise with the unit running, watch the low side pressure drop, when it nears 0 shut down the unit and you will have captured 95% of the freon in the system.
Jun 27, 2009 | Heating & Cooling
Need the BTU rating for an old Kenmore K948991 a/c
Your model number is not complete enough for a model check.
However, 18,000 btu in todays' units is what you need.
Mar 28, 2009 | Kenmore Heating & Cooling
Need to know how to do a hard reset on the unit-lowrance533
try this ,
1.) turn off unit
2.) press and hold pages key
3.) press and hold power key
4.) release both buttons when the USA map appears
was for the 5300 searies , hope it helps ya.
Dec 25, 2008 | Lowrance 5300C GPS Receiver
Does not want to work
You will need a brain to run the head unit. I have 3 of the same units. If you want to sell your head unit let me know, other wise its useless.
Jun 02, 2008 | Kenwood Excelon KVT815DVD Car DVD Player
Optical unit for RXD25
i got a website you can go to to find that info "www.partsstore.com"
Apr 16, 2007 | Panasonic RXD25 Cassette/CD Boombox
Polk Audio SurroundBar Center Speaker Logo
27 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
