Question about Simpson Garden
Crack in outlet end of my power washer msv3024
Crack in housing
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: Where can I find the
There is a hard surface connector on the power panel
Your parts manual is here:
http://www.powermate.com/pdfs/2007/11/17/parts_pm0497000.pdf
Owners manual:
http://www.powermate.com/pdfs/2007/11/17/manual_pm0497000.pdf
If you call coleman they will tell you that you need to replace the entire power panel PN 0062693.
IF the 30A recepticle connector is damaged you can get them at Home Depot, Lowes, Mernards. The recepticles are usually Eagle brand. Same goes for the cord plugs... You would need a male connector and the source is the same. HD, Lowes, Menards et all. Most LOCAL lawn mower parts sources can get them also
L1 to the left
L2 to the right
Neutral bottom center
You can find the plugs RH side this page also:
http://www.electricgeneratorsdirect.com/accessories.php
If you call Grainger or Northern tool (
You did not mention if it was a 3 pin or 4 pin plug. It does make a huge difference on the plug connections.
Posted on Aug 27, 2011
No suction when using hose attachments - motor runs and under cupboard vent works - just not able to use just the hose with attachments
does the vacuum turn on when hose plugged into wall outlet assuming your using central vac. if it does not turn on then the metal band in the hose end is possibly cracked.
Jan 03, 2015 | Vacuums
Where are the fuses located on the front load washermachine
Could it be the house fuses? I doubt there are fuses in a washer.
Sep 25, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Clarke power washers 150
Need more info:
What fuse? the one at the end of the cord on the pressure washer? Or the circuit breaker on your house?
If it is the one on the cord it may have gone bad. To test replace it with normal plug (non-GFI) and plug it into an outdoor or bathroom GFCI (GFI) outlet. If it still trips that outlet then there is a ground fault in the device which may be minor or major.
If it is a home circuit breaker remember that electric pressure washers use a lot of power - typically 1500 watts. If anything else is plugged in it can trip the house circuit breaker.
Jun 04, 2014 | Garden
After the winter my motor runs fine but no water pressure
Did you drain the pump in the fall? Cracked housing or blown gasket.
Apr 22, 2014 | Garden
Fixya com
  • Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
  • Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
Perform an AC Adapter Reset. To perform an AC Adapter Reset follow these instructions: Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
  1. The AC adapter must remain unplugged at both ends for a full two minutes.
  2. Unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
  3. Check the AC Adapter for the following:
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If the AC Adapter shows signs of physical damage and needs to be replaced, a replacement can be purchased from Nintendo's online store.
  4. After waiting two minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then the AC Adapter reset was successful.
If these suggestions don't work try visiting Nintendo's help pages at: http://www.nintendo.com/consumer/systems/wii/en_na/ts_system.jsp
Apr 21, 2013 | Nintendo Wii Console
Kenmore 20022011 washer.... Mike the 3 wires i found are the power in to the washer...... now what????
the wires are green=ground black=power and, white=neutral
check them for power with a meter or, plug a good lamp into the electrical outlet the washer uses; no power? check the circuit breakers in the house load center
Feb 04, 2013 | Washing Machines
I have a 9 yr old KUDS01IJBSO and there is no power to the control panel and the breaker is not tripped. Is this likely to be an electronic control panel failure?
check the outlets, may be a GFI outlet tripped, check the switches with washer on. If you have aluminum wire in house may be the connection to the washer.
Mar 10, 2010 | Dishwashers
We have a GE front load washer WCVH6800. Recently we loaded some throw rugs into the washer. These rugs released a large amount of material. We cleaned the pump filter 3 times and it now seems clean. ...
The water inside the tub will drain out when the pump filter is removed from the pump housing and flood the base of the washer. If not, the tub drain hose is clogged preventing the water to drain into the pump housing then out.
The door is locked because the foam switch in the pressure switch is open due to the presence of water after the unsuccessful drain cycle.
Disconnect the washer from the power outlet. Remove the three screws holding the lower front access panel to the cabinet and pull the panel down to access the pump housing.
Squeeze the clamp that hold the tub drain hose to the pump housing and slide it back. Prepare a pan to catch the water to prevent flooding. The tub drain hose maybe difficult to remove and you may need to insert something under it to break the seal and pull it off.
Remove the tub drain hose from the tub by squeezing the securing clamp and pulling it off the tub drain outlet. Clear the hose and the tub drain outlet from any debris.
Reinstall the tub drain hose and manually unlock the door before reinstalling the access panel. Reach and pull the release ring behind and up the right side of the front panel, then open the door.
Feb 14, 2010 | Dryers
KENMORE Elite HE 3T
no but there is a control bd it is probably gone
Jul 30, 2008 | Kenmore Elite 45986 Front Load Washer
Moved Washer and Now no Electrical
Suggestion: You dont need any special outlet. With a tester (you can get this in any electric shop) see if there is power in the outlet. You said it was hot?? It is not supposed to be hot. Try another outlet; & you could unscrew your machine plug to see if all the three wires are okay, ie. well connected, screwed in.
Sep 21, 2007 | Kenmore Elite 45986 Front Load Washer
Garden Logo
54 people viewed this question
Top Simpson Garden Experts
John Trevino
JOHN LAPIER
ray gallant
Are you a Simpson Garden Expert? Answer questions, earn points and help others
