Question about Elite EPC607 Pressure Cooker
Fault code e4
Press button and fault code e4 comes up how do i fix it
    New Friend:
I found two loose wires, and tightened the screws, and the e4 went away, and it works now. The plastic cover on the bottom has to be removed to get to the wires and screws. Make sure it's unplugged
Posted on Dec 24, 2017
What does E 4 on display panel mean?????
Hi Noreen,
The "e4" is an error code. You need to search online for "error code e4 + your make". You should then, at least, know what the problem is.
Aug 25, 2015 | Crock Pots & Slow Cookers
How can I fix E1 code? on the digital display?
Factory reset the slow cooker. To do this, and this is only an educated guess as no information is available in the user manual for this device, is hold the clear button if there is one while powering it off, or press the + and - buttons simultaneously and hold for several seconds to clear the screen.
Jun 07, 2015 | Cuisinart PSC-650 6.5-Quart Slow Cooker
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
Keeps coming up E4Pressure cooker
Here is a piece from someone who had the same E4 error problem:
I had this problem. I noticed that steam was coming out almost immediately and the cooker would not start counting down. Eventually, the "E4" display would appear. I determined the steam vent valve (loose piece) was not seated on the vent hole in the cover so the pressure never built up. I removed the loose piece which consists of a metal cylinder and a black plastic cover with a handle. The plastic cover was so far down on the metal piece that it would not allow the metal cylinder to seat on the vent. You can use the metal piece by itself or work the plastic cap up far enough so that the metal piece seats on the vent in the closed position. I have had no more problems - it works fine. good luck! kc
Mar 18, 2011 | Wolfgang Puck 5-Quart Electronic Pressure...
Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
My Wolfgang Puck pressure cooker shows 'E4' in the display.
There doesn't seem to be any legit way of fixing this. I tinkered with the pressure sensors and valves, kicked the pressure cooker a few times, still the E4 error presented itself.
Pics of process:
May 10, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
E4 on the Woldgang Puck Electric Pressure Cooker
I fixed mine by elevating it 4 inches (E4) and dropping it on the counter. Something needed a little impact adjustment!
Mar 18, 2009 | Wolfgang Puck Electric Pressure Cooker...
Rival 38601 Smart Pot 6-Quart Slow Cooker can't get to to go to warm
Here is the manual for this cooker; http://www.crockpot.com/manuals/38601-C_English.pdf page E4 and E5 tells you details of programming/timer/temperature. Check through everything and see if you can figure anything out. after cooking, the unit should automatically switch to warm mode, if it isn't doing this then unfortunately i think it needs a replacement control board - probably not worth doing. If you want to give it a try then post again and we can try and source you the bits Hope this helps :)
Mar 16, 2007 | Rival 38601 Smart Pot 6-Quart
Elite EPC607 Pressure Cooker Logo
143 people viewed this question
Top Elite Crock Pots & Slow Cookers Experts
tsalagi152
Darrell
Are you an Elite Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
