Question about Vizio VA26LHDTV10T 26" LCD HDTV
The television screen is frozen
The tv screen is frozen saying there is no device connected to the tv!
Trying to take tv off of av screen without the remote lost it
Turn off the device connected to the av output, then turn TV off and on again!
Aug 05, 2015 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Frozen screen
Unplug your cable box from the wall outlet. Wait 3 or 4 minutes and plug it back in.....TV should now be normal.
Sep 06, 2014 | Televison & Video
I am trying to connect my laptop via VGA cord to my 65" Mitsubishi Medallion, but when I click on the VGA device selection in the device menu, it goes to a blue screen and says "Warning: Turn on...
Press the Windows key + P on your laptop.
Or, if that doesn't work, look on your F keys for something that looks similar to a monitor.
Press the FN key and that key.
This should bring up your laptop's display on the tv.
Mar 09, 2011 | Mitsubishi WS-65809 65" Rear Projection...
TV turns on, but a picture from previous channel I was watching is frozen to the screen. I've unplugged cable cable card and connection to cable service and picture is still frozen on screen. Will not...
sounds like a burn-in but are you saying that you can view another picture but no clear because the previous picture is still there. A burn-in is a tv being left on a fixed object like a picture and left there so long this is what you see when you change channels the image burned on the screen, is this what you have?
Jan 06, 2011 | Hitachi 42HDS69 42 in. Plasma Television
My remote is frozen on 'watch tv'' . device button, help button will not work. off button not working, initial screen to turn on devices does not appear. remote is fully charged
Hi, try updating the firmware in safe mode.
1. Remove the battery, press and hold the 'Off' button, and re-insert the battery. The screen will say 'safe mode'.
2. Connect to the software and click 'Downloads' at the top of the screen.
3. Click 'Firmware'.
4. Update the remote
Mar 20, 2010 | Logitech Harmony 890 Universal Remote
What does it mean when a viewsonic says no signal
No input signal from your computer or external device is being received. Could be loose connection or connected device not powered up or asleep. If laptop connected you need to toggle external screen <Fn><F8> toggles through displays.
Feb 08, 2010 | ViewSonic VT2430 LCD TV
"frozen" unless connected to TV
See if you can take pictures with it- ignore the screen for the moment. The fact that the welcome screen comes on - suggests that the screen itself and its connections are OK. Displaying images on the TV say those parts are OK. Taking it apart to 'clean' is not advised there is nothing there that you or I can fix. With this clarified Go to the Nikon website and check with Technical support team.
May 29, 2007 | Nikon COOLPIX Cameras
Channel jumping
Sounds like the PIP feature is causing the problem with the TV if you are connected directly to cable TV without a box inline and getting these issues.
Apr 10, 2007 | Sony KV-36XBR450 36" TV
Vizio VA26LHDTV10T 26" LCD HDTV Logo
14 people viewed this question
Top Vizio Computers & Internet Experts
justwinwin
Are you a Vizio Computer and Internet Expert? Answer questions, earn points and help others
