Question about Grandstream GXP1450
Factory reset grandstream
How to factory reset grandstream GXP1450
Reset password for grandstream gxp1450
What is this and what does it do?
Sep 22, 2016 | Grandstream GXP1450
How to unocked keypad
press *** on the keypad, then enter from the softkey. If the phone keypad was accidently locked you can unlock it without a pw, but if was intentionally locked with a pw the only way to unlock it is either with a pw or to factory reset the phone
Apr 22, 2015 | Grandstream GXP1450
How to reset admin passwod gxp285
The default administrator password is "admin"; the default end-user password is "123".
You would need to do a factory reset if those don't work, but beware all your configurations will be overwritten.
See instructions here P44 http://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Jun 27, 2014 | Grandstream GXP285
How do I unlock grandstream 1405 keypad
Press '*' Star for more than 4 sec then it will show the password to input if you have put it or simply press OK.
May 30, 2014 | Grandstream GXP-1405
Factory Reset Grandstream GXP 2000 w/o using the menu?
From the Granstream User Manual (Page 44):
Restore Factory Default Setting
WARNING: Restoring the Factory Default Setting will delete all configuration information of the phone.
Please backup or print all the settings before you restoring factory default settings. Grandstream is not
responsible for restoring lost parameters and cannot connect your device to your VoIP service provider.
INSTRUCTIONS FOR RESTORATION:
Step 1: Press "OK" button to bring up the keypad configuration menu, select "Config", press "OK" to
enter submenu, select "Factory Reset" (Please refer to Table 5-1 of keypad flow chart)
Step 2: Enter the MAC address printed on the bottom of the sticker. Please use the following mapping:
0-9: 0-9
A: 22 (press the "2" key twice, "A" will show on the LCD)
B: 222
C: 2222
D: 33 (press the "3" key twice, "D" will show on the LCD)
E: 333
F: 3333
Example: if the MAC address is 000b8200e395, it should be key in as "0002228200333
395".
NOTE: If there are digits like "22" in the MAC, you need to type "2" then press "->" right arrow key to
move the cursor or wait for 4 seconds to continue to key in another "2".
Step 3: Press the "OK" button to move the cursor to "OK". Press "OK" button again to confirm. If the
MAC address is correct, the phone will reboot. Otherwise, it will exit to previous keypad menu interface.
https://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Apr 03, 2014 | Grandstream GXP-2000 IP Phone
How to unlock gxp1450 keypad?
COMO DESBLOQUEO EL TECLADO DE MI TELEFONO POR FAVOR
Jan 17, 2012 | Grandstream GXP1450
A wrong pass word was entered and the devise was blocked.how can i access the device again?
you would need to factory reset the adapter if you dial *** then 02 it will give you ip address now if you put the ip address into your main web browser it will pull up a configuration page for your handy tone you will see a tab on the left hand side that says reset click that and factory reset the device this should wipe out all current configurations on tht device
Oct 07, 2009 | Grandstream HandyTone 486 ATA (HTATA486)
Grandstream password recovery
if you have a password reset disk use that.otherwise
you must use the password recovery software
Feb 14, 2008 | Grandstream GXP-2000 IP Phone
Grandstream GXP1450 Logo
117 people viewed this question
Top Grandstream Computers & Internet Experts
David Payne
David Payne
Are you a Grandstream Computer and Internet Expert? Answer questions, earn points and help others
