Question about Swisher 60" 26 Hp Zero Turn Radius Riding Mower #Zt2660b
Right side hydrostatic freezes up after runing a few mins
After running a bit it freezes up and smokes the belt
SimplictyYRZ01 hydrostats not engaging
The only thing the two hydrostatic drives have in common is a drive belt that ties them to the crankshaft. If both side quit at the same time that belt is most likely the problem.
Jul 09, 2016 | Garden
Smoking white
Probably going to need new piston rings. Pretty sure your burning a little oil.
Feb 10, 2014 | Suzuki Motorcycles
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My toro zero turn seems to overheat and stops moving from left side about half hour it runs fine.?
First check to see if you have any leaks especially on the problem let side. This includes the wheel motor. where hydro oil comes out, air can go in. either way it sounds like you need to take your pump out and open it up and check for metal inside. If you do not have any metal inside check the 5 pistons to see if they are stuck. What series hydro pump do you have?
10L 10A etc.
Jul 28, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Air con run a few mins then stop.
the system may have a bad condenser fan motor or it is not charged right with freon and it is over heating if the fan stays runing and it is just shuting off the compressor try to clean the coills on the ac system with water and wash them good
May 09, 2011 | Heating & Cooling
2003 DODGE NEON > First
Sounds like alternator belt burned and broke.
Apr 03, 2011 | 2002 Dodge Neon
How to replace drive belt on john deere model 345
- remove deck
- remove seat and rear fenders
- pry off deck adjusting knob
- remove F/R pedals
- remove floor plate
- use jackstands to prop up entire right side of tractor
- remove (2) screws holding fuel lines on side of frame
- lift out gas tank, set alongside left side of tractor
- remove plastic fan from hydrostat
- disconnect the electrical connector for the electric clutch
- from the top-side - use a 3/8" drive rachet - stick it into the tensioner slot next to the idler, rotate it to take tension off the belt, and remove belt off hydrostat pulley
- from underside - remove front idler (next to electric clutch)
- from underside - remove the "right-most" idler off the spring tensioner
- from underside - remove the "left-most" idler off the spring tensioner
- now the tensioner can rotate fully to take almost all the tension off the extension spring
- pop the spring off the tensioner arm
- the belt should now be able to be removed from the machine
- reinstall in the opposite fashion
- note: to reattach the spring, connect a nylon cord to the spring, and pull it rearward and guide it onto the tensioner arm - you need to stretch it about 1"
- for reattaching the two idler pulleys to the tensioner, get someone to hold the ratchet so the tensioner is positioned for the belt being in it's most-loose position. You may need to wrap the new belt around the hydrostat pulley first, and assemble the last idler pulley and belt at the same time to complete the procedure.
Apr 20, 2010 | Garden
Dryer rune for a bit then shuts off - won't start
clean link from bottom of dyer and exhaust vent
Aug 07, 2009 | Kenmore 63942 Dryer
Runing rough for 1 min. after start cold engine
What car , and year and engine? What color smoke?
Oct 18, 2008 | 1994 Volkswagen Golf
Swisher 60" 26 Hp Zero Turn Radius Riding Mower #Zt2660b Logo
Top Swisher Garden Experts
Tim Whalen
dannydoesita
ray gallant
Are you a Swisher Garden Expert? Answer questions, earn points and help others
