Question about Bosch 24 in. SHX46A05UC Built-In Dishwasher
Unit will not power on
I replace the on off switch still no power
What remedy to turn the unit operational
Check the batteries of your remote control, replace the batteries, press power button. You should hear a click from the unit. If no sound from the unit, check if there is power going to your unit. If no power, reset the breaker by pulling the handle to off position and then switch it on. For disconnect switch replace the fuse and then switch it in on position.
Mar 04, 2016 | Heating & Cooling
Dryer will not run
though there is power supply to the unit but don't start you have to check the door switch. if switch is ok and still unit don't start check the starting capacitor if equipped. replace if bad. if unit won't start even with a good capacitor and good door switch , then check the motor switch. if motor switch is bad replace the whole motor. switch and motor are sold together.thanks.
Mar 01, 2016 | Whirlpool Dryers
Where can I find a replacement power switch?
Power switches are safety components that can only be replaced by manufacturer approved parts. Contact Crosley for where you can get approved parts.
Nov 24, 2015 | Crosley Entertainer CR-79 Turntable, CD,...
Init unable 50
Set the maintenance unit into place, if the planetary arm does not
move smoothly, clean it. purge cam switch harness not connected correctly,correct the connection,purge cam switch broken replace the maintenance unit, gear(s) on the maintenance
unit broken paper feed motor defective replace the engine unit,
power supply PCB defective replace the power supply
PCB. Main PCB defective replace the main PCB.
Dec 02, 2013 | Brother DCP-195C Inkjet Multifunction...
Won't turn on
First check to see if you have power to unit, Check beaker or fuse. Reset or replace , Restart and check with a voltage meter. If you have power to unit from wall then check to see if you have power to the controller, if you have no power to controller then likely cause: Transformer open.
Solution: Replace transformer. Make sure there is power to the on/off switch and going through the switch to the controller, if you have power to switch but not through the switch when in the on position then replace switch. Check this first.
Jul 10, 2013 | Scotsman Kitchen Appliances - Others
I get the error code FSE1, lock won't engage message for the bottom oven everytime I turn on the top or bottom unit. The message will not go away until I turn the top unit off. The bottom lock keeps...
F5 - E1 Self clean latch will not lock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Apr 19, 2011 | KitchenAid Architect KEBS208S Electric...
Hi, I have a memorex portable DVD player (MVDP1085) and won't power on. when I insert the power adapter in to the unit the charging indicator starts flahing which means that it's charging the battery and...
On side of the unit you will find an AV switch. Make sure that switch is on the OUT position. Then power up the unit again and try to play a disc.
Boards for these units are hard to come by. Most portable DVD players are replaced when they fail due to continued declining prices.
Aug 18, 2010 | Memorex Televison & Video
The power windows just quit working. I have replaced the circuit breaker (30A), removed the door panel and checked the power to the window switch unit. I get 12 volts to the switch unit. It's all four...
If there is power to the switch, the switch is the point of failure. You can verify by checking for power at the window motors when the switch is pressed. It is also possible that there is a faulty ground connection from the switch, but this is unlikely. 99% chance replacing the switch assy. will solve the problem.
Jun 21, 2010 | 1995 Jeep Grand Cherokee
C-7 990 error code just keeps showing up on copystar 1500 copier
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine board
Aug 19, 2009 | Copystar CS-1500 Copier
I get an error code on my Whirlpool RF362BXKW range. I have shut down the power to the unit, have cleaned the unit and the error code won't go away. None of the oven cooking options work with the error....
What I did was hit cancel and hit the unlock button. Then I leaned against the door a bit as I hit the lock and hit the self clean and start the lock check dissapeared. I hit lock again and nothing else and it started the cleaning process.
Apr 08, 2008 | Kitchen Ranges
Dishwashers Logo
42 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
