Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
Bypass temp sensor
Temp sensor bypass
What are the probable causes of DTCs P0030, P0039, P0074, and P0098?
code p 0030 refers to heated oxygen sensor (HO2S) 1 bank 1 -heater control-circuit malfunction
code p 0039 refers to turbo/super charger bypass valve , control circuit --range /performance problem===causes --wiring--- bypass valve
code p 74 refers to outside air temperature sensor--circuit intermittent===causes ---wiring---poor connection---out side air temp sensor---ECM
code p 0098 refers to intake air temp (IAT) sensor 2 --circuit high input===causes --wiring short to positive ---IAT sensor---ECM
Nov 23, 2015 | 1994 Cadillac DeVille
How can we bypass the cooling sensor by the thermostat?
Om most vehicles, you can't. The coolant temperature sensor sends a variable signal to the ECM based on coolant temp, and that value is used by the ECM in the computation of the fuel mix (rich/lean) to the injectors. Without it, the vehicle will run poorly, if at all, and will set the Check Engine Light. There MAY be a separate coolant sensor that simple controls the radiator fan. This one could be bypassed, but that comes with great risk of engine overheating and damage. Most newer cars use the coolant temp sensor for both the fuel mix and the radiator fan with the fan on/off signal controlled by the ECM.
Oct 11, 2015 | Cars & Trucks
FL1 on a Jandy Lite2 LJ250N even after replacing the temp sensor.....is there any way to bypass the sensor to see if there is a different problem?
if you replaced the temp sensor and it still does that check to see if you didnt short the wires if all ok sounds like pcb board
Aug 10, 2014 | Jandy Pool & Spa
Kohler 40 kw adc controls troubleshooting
wow intermittants are tough to find , the only way ive ever been sucessfull at it is to temp bypass each sensor (lie to controller) to see if it continues to run ,I do not recomend leaving any thing bypassed and not physicaly monitoring it ,
this temp bypassing is for only the most experienced techs that know normal state of sensors and can simultate them with off machine items
Jun 17, 2014 | Kohler Electrical Supplies
Why does my Pentair master temp reads 225 degrees
bad temp sensor or hooked up backwards or bypass stuck open
May 03, 2014 | Sta Rite Sr200lp Max E Therm Pool & Spa...
My confort zone infered heater comes on for a few minutes then shuts down
Does it shut off heater with lights and fan on or power off? Did you bypass the temp sensor or thermostat? If temp sensor that mounts above filter, see http://www.fixya.com/support/t15119324-comfort_zone_cz2011_heater_shuts_off .
Feb 14, 2013 | Comfort Zone CZ1500WC Infra-Red...
Where is the temp gage sensor location 2001 merk cougar
The temperature gauge relies on readings from the Engine Coolant Temp (ECT) Sensor.
The ECT sensor is usually located on (or near) the thermostat/coolant housing.
Refer to component No. 8 (2.0L Engine):
Refer to component No. 9 (2.5L Engine) locate under bypass tube:
Hope this helps.
Cheers,
Aug 27, 2011 | 2001 Mercury Cougar
2000 bettle 1.9L turbo will only start if you unplug coolant temp sensor
Hello and welcome to FixYa!
If that's the case, I strongly suggest that you replace the coolant temp sensor. Looks like it's faulty and grounding the circuit. The car's computer can detect it that's why it won't start but once you disconnect it, it will for the coolant sensor is bypassed.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 14, 2011 | 2000 Volkswagen Beetle
Temp sensor
Bypassing the temp sensor may cause a FIRE!!! I don't recommend this.
Aug 14, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
53 people viewed this question
Jerry Greenberg
Jerry Greenberg
