Question about RCA RP5430 Clock Radio
Lost clock on 318ti dash after flat battery
After flat battery on my 318ti bmw cannot get the time back on radio and dash ,how to reset
Lost power to my house, came back on outlet has power clock on radio works radio has no power. wall clock on same outlet works fine
There is a battery backuo in the radio. This is probably powering the clock. It looks like the radio power supply is either fried or the hardwired fuse is blown.
Take a look at the manual. If you take out the battery back up does the clock still work? GPX MP3 Player KC232S user manual
Apr 12, 2015 | Audio Players & Recorders
How do I change the time on my 2007 BMW x3
The clock on the radio and on the dash are synchronized. There is an oil check button located between the odometer and speedometer. Press and hold the right button ( oil check ) for a few seconds. You will see the time flashing. Press the left button to adjust the time. You will find the instructions in your owners manual.
Nov 10, 2012 | 2007 BMW X3 3.0si SAV
How do you change the time on the clock in a 2001 BMW 325i. The manual does not say and my clock is running 8 minutes behind.
there is a button located on the end of the turn signal that controls the clock function on the dash and the radio clock.
Jan 28, 2011 | 2001 BMW 325
Im needing the camshaft timing marks for a 2003 bmw 318ti E46
Hi, this is the camshaft timing marks for a 2003 bmw 318ti E46 HERE....
Oct 04, 2010 | BMW 318 Cars & Trucks
Lost user manual...how do I reset the time? I took out the batteries and unplugged the clock but now it will not reset itself
I lost a user manual, then found these guys. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
Sep 22, 2010 | RCA RP5430 Clock Radio
I have a 1997 bmw 318ti. on board computer
Hmmm. The unit that calculates the fuel is under the back seat base. There are two level sensors under covers on either side. Could be that you have a trapped wire shorting and when you go into reverse the back axle just momentarily jogs the shorted wire. I'd look at the wiring there.
Mar 25, 2010 | BMW 318 Cars & Trucks
HOW DO I SET THE CLOCK IN THE BMW Z4?
between the tachometer and the speedometer on your dash, you have two buttons
"S/R" on the left and one with a clock on the right.
press the "clock" button for a few seconds until the hours (or --:-- if never set) appears
on the "screen" under the speed meter and the column sign flashes.
press the S/R button to increase the hours until appropriate.
press the clock button again to pass to the minutes.
press the S/R button to increase the minutes until appropriate.
press the clock button to confirm the time.
at that point you are all set, and the clock on the radio should be ok too.
Every time you jump start the car, you will have to reset the clock though.
May 12, 2009 | BMW Z4 Cars & Trucks
For 2002 BMW 325i. how can i reset the oil service indicator after an oil change. and how to activate the clock after i changed the battery (the clock does'nt show the number only dash after i changed the...
WHILE HOLDING LEFT ODOMETER RESET BUTTON TURN KEY TO POSITION 1, HOLD FOR 5 SECONDS , SIGN STATING OIL- INSPECTION RESET, ETC SHOULD APPEAR , LET GO AND HOLD AGAIN, A SIGN WILL FLASH, PRESS THE BUTTON THIS TIME.
I T BELIEVE IT WILL WORK OUT.
Apr 05, 2009 | 2002 BMW 3 Series
Clock
hi..
put your keys in so that your instrument clsuter on the dash come on,(no need to start the engine), use your mileage reset button to change time by turning it clockwise and anticlockwise till you reach the correct time.. it will change on your dash aswell as your radio..
Jan 05, 2009 | 2005 BMW 3 Series
Needles flying around the clock
I have a mantle clock version and to set the clock to recognize the radio signal, I need to hold down both the ET and PT time zone buttons for a few seconds. The clock hands will then continue to move until they reset themselves to the correct time.
Nov 03, 2007 | La Crosse Radio Controlled Atomic Clock
RCA RP5430 Clock Radio Logo
14 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
