Question about Sebo Automatic X1 Bagged Upright Vacuum
Diffcult to push on carpet
Brush not lifting
Dirt Devil upright has too much suction.
In a world where most people wish their cleaners had more suction, yours is a rare complaint indeed. Upright cleaners in particular are complaint-worthy as they soon tend to lose suction. It would be good to read more about the reason for your complaint?
Ideally an upright will have enough suction to lift the carpet from the floor a few mm and trap it against the mouth of the brush housing so air can be drawn through the carpet helping to lift out dirt so the brush can work more efficiently. An upright that is working correctly is much harder to push along and as they age they tend to be easier to push as they lose efficiency.
Most cleaners are fitted with at least one filter and they do rob them of suction. Some people remove the filters to improve the suction. Perhaps your cleaner has one or more filters missing.
May 06, 2017 | Dirt Devil Vacuums
Brush rolling but the machine will not roll on the carpet
check to see if there is a button to push to lift the front part of your vacume up maybe to close to the carpet or your back wheels have something stuck in them
Jul 13, 2016 | Shark Navigator Bagless Upright Vacuum
My Shark rotator is very hard to push at times, easy at other times. What makes it hard to push and how do I fix it?
Does it have a "brushes" lowering/higher switch?
Normally due to brushes being too low in particular on deep pile carpets??
check the actual fixings for the rotating brushes are ok and the brush not simply need "clicking" back into place?
Feb 12, 2015 | Shark Rotator Professional Lift-Away...
Why does my kirby shake ?
If your Kirby is just sitting on a hard surface and is shaking, something is either on the fan or brushroller putting it out of alignment. Here is how to change the fan / impeller if broken.
how to change Kirby fan / impeller.
If it shakes while you are pushing against the carpeting you can try adjusting the height of the brush until it is just touching the carpeting. Some thick pile carpeting the Kirby will still shake or jump on, the strong suction causes it to trip over the thick pile that is lifted up when vacuuming.
GoodVac.com
www.goodvac.com
1-800-775-6586
Oct 05, 2014 | Kirby Vacuums
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
My dyson vaccum feels heavy and slow when pushing it. Please advise. Thanks
First make sure that brush roll is moving not broken belt....if all ok then try setting height for thick pile carpet lift head a bit this will ease off on a thinner carpet and in turn make it easy to push,
Jul 04, 2011 | Dyson Vacuums
Can I lift the vacuum beater bar higher up? Bought new carpet and would like it to push smoother!!! Bought a shag carpet
No. The Electrolux (Aerus) uprights are auto adjusting to the height of the carpet. Make sure the brush is spinning when the vacuum is on. If it's not, this will cause difficulty in use.
Apr 06, 2011 | Electrolux Epic 3500 Vacuum
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
I would like to disassemble my eureka altima to clean brushes
The Altima line has 2 screws on the hood (part where the knob is that says high carpet and low carpet) that you remove with a philips head screwdriver then you just lift the hood of the vacuum
Mar 08, 2009 | Eureka 402A Bagless Upright Vacuum
I need more suction. The Head is too high on my carpet.
Hi.
A slitght adjustment can be made by either screwing on short transparant internal hose on top of floor head tighter or undoing it turn.
Do this on A table as you need to get down to be able to view sole pate movement
Each time you adjust hose stand vac up on the table & pull handle back as if cleaning carpet you must not push head of vac down on the table.
Now look at sole plate usually when they are wrong the sole plate bottom back end tilts up lifting brush from carpet.
Now tap front of head down if sole plate springs back up lifting brush up again adjust hose a bit more.
What you are trying to do is get sole plate as horizontal as you can.
If you really cant get it to pick up dirt any better try fitting new hose they are more sprigier from new,
http://dysonmanuals.llc.nu/
Jan 02, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Sebo Automatic X1 Bagged Upright Vacuum Logo
Top Sebo Vacuums Experts
Nick Olsen
Masters Engineering
Level 1 Expert
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
