Question about Mustang 1969 Ford Mustang Boss 302 Through The Wall Mural
Bleed master the brake pedle will not get hard
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
You don't mention if you have 4 drum brakes or 2 drums and 2 disc. Assuming you have air in the lines, begin with the lines that are furthest away. Check that the slave cylinders are good and not leaking fluid. after you have purged each wheel, if the pedal is still weak, then replace the master (Bendix brand) cylinder.
Posted on Oct 20, 2015
Why does f150 brake pedle fades
Hydraulic system pressure too low. Brake system needs one or more of the following issues resolved.
1. Bleed brake system
2. Master Cylinder failure
3. One or more of the wheel cylinders have failed
4. Leak in hydraulic systems (assumes constanlty need to add fluid)
Aug 27, 2014 | 2003 Ford F150 Regular Cab
4runner
What kind of problem?
Jun 11, 2013 | Cars & Trucks
Hi i have just replaced master cylider and put a kit thro the rear caliper on my harley ,it bleeds up but when you go for a ride i loose my brake it has no leakes and no air in the at all as it has been...
There may be air in the system, also may be out of adjustment, or could have a warped rotor. do the brakes shake at all when you apply them?
Apr 20, 2013 | Cars & Trucks
Replaced front caliper bled brakes but peddle will not come back all the way and it feels like the brakes are on.
bleed them more you still have air in the line. and bleed all brake lines front and back.if after that no pedle could be a bad mast er cylinder
Apr 14, 2013 | Cars & Trucks
Brake light stay on after changing brakes and rotor on my chevy s10 thanks ds
sir i need more info did old pads have wires on them and is the pedle going down a little to much and did you bleed calipers .now if you bleed brakes you may have the float in master cyl not up high enough for lite to go out it may be low on fuild or float stuck if this does not fix write in with year and make and motor and if you did anything to master cyl sometimes you have to pump up master after you do front brakes i was a brake machanic for 25 years and taught it to many students larry p
Sep 07, 2011 | 2000 Chevrolet S-10
Brake servo master cyl flexing and moving to bulk head making the foot brake pedle spungy soft insufistant reserve travel
I think your saying you have a spongy pedal. have the brake system checked for leaks ( externally as well as internally eg master cylinder) and wear. If a-ok then have them bleed the system.
Now if your saying there is a problem with pedal travel
that has to do with pedal rod adjustment( which is only adjusted after replacing a master cylinder or booster)
Apr 14, 2010 | 2000 Ford Escort
I have 1975 international B 1700 I have replaced brake shoes wheel cylnders brake lines hydro vac checked vacum 17 #s and have no brakes the pedle can be pumped up and is rock hard with no stopping power I...
hte brakes may need to be bled also check for air coming out of the lines while bleeding yo may see air pockets haqve you checked to be sure that the master cylender is any good?
Oct 08, 2009 | Ford F-450 Cars & Trucks
1992 Buick LeSabre brakes bleed but very lil brake at pedle
start bleeding your brakes from the rear wheels and work your way to the front. I'm assuming you already did a pad change since you say you got the air out. make sure you keep the fluid level and not let it get too low while you're bleeding them or air will get into the master cylinder and you have to start all over again. Make sure you have someone help you that is competent enough to hold the brake pedal down all the way and not let off even the slightest bit until you get the bleeder screw tightened.
Feb 03, 2009 | 1992 Buick LeSabre
Mustang 1969 Ford Mustang Boss 302 Through The Wall Mural Logo
101 people viewed this question
Top Mustang Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Mustang Toy Expert? Answer questions, earn points and help others
