Question about Gear One PA2400 / Kustom KPC15 PA Package
How do i connect my laptop to the Gear one 2400 PA system
How do I connect laptop
I need to know howon How. to connect the moniters and speakers on gear one 2400 pa
William,
There should be 2 quarter inch jacks on the front lower right of the unit. One is labeled Monitor and the other is Mains. There should also be a selector switch(Amplifier Assign) below the phantom power switch for selecting how you want to the quarter inch jacks to operate. Set that switch to L+R/Monitor. This should be the center of the selector. Plug your monitors into the monitor jack and your speakers into the mains jack.
Oct 02, 2017 | The Computers & Internet
Tip
My dell pa 12 won?t start ?
When i start my dell pa 12up and it takes 10 mins to load to windows XP, , when the windowsloading screen comes up the FANS go crazy. I then wait till i’m at thedesktop at which point i immediately shut down the pa 12(which takes afurther 7 mins) while the FANs are going crazy.
answer :
Now if i start the pa 12 again it works normally.
I had to do this procedure everyday, untill today when i switched the pa 12 on, waited till the desktop appaered and i removed the battery while the pa 12 was on..
Now when i switch the pa 12 on it powers up but i’m not getting anything on the screen
First try a different AC adapter (such as :pa 10 ac adapter)
If no change then the issue is the motherboard. Often the AC adapter will fail then the battery discharges and you get the symptoms youdescribe.
SO AC adapter then MB
It shows no power on your laptop but it shows you the dvd player led comes on then off.
I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter (hp dv6000 ac adapter)tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If laptop AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
on Feb 09, 2010 | Computers & Internet
NEC 2400 Troubleshooting pbx issue
What is the problem?, i could help. Do you paypal?
May 13, 2013 | NEC 2400 Pa-8cftd Conference Trunk Card
Lost manual. I need to know how to hook a TDK-3826 dual recorder to a PA System at church to record the services and what CDs to use.
Hi wpless43!
The TDK-3826 supports analog input/output, digital coaxail input/output, and digital optical input/output. To connect a PA system, you'll have to determine what type of connection it uses. If your PA system uses an analog connection, it will have two audio cables, one for the left sound channel and one for the right channel. These are color coded and can be connected to analog connections on the back of recorder. Coaxail and optical connections are both single cable connections, and can be connected to their respective locations on the back of the recorder.
Regardless of the connection used, you'll want to connect one of the outputs of the PA system to the recorder if you want record. If you want to use the recorder to play back audio over the PA, you'll want to connect the output of the recorder to the input of your PA. Most PAs support multiple outputs and inputs, so you should be able to connect the recorder input and output at the same time.
You'll want to use CD-R/RW discs to record, but make sure they are audio discs (See image). joehaydu.jpg
You can find a copy of the manual for the TDK-3826 at http://audio.manualsonline.com/mdownloads/bd4c0d62-6f82-4bfb-bf83-8d832f3fe222.pdf. Hope that helps!
Mar 05, 2011 | Computers & Internet
Where do you plug in a PA system on this HP Pavilion dv7-3164 Laptop computer?
Hi, if you have an head phone socket on the side of your laptop then this is where it will plug in, how ever you may need to go to a computer store and buy an adaptor so as the pa system will fit into the smaller laptop haed phone socket.
let me know what kind of fitting the pa system has then i can tell you what adapter your going to need ok
Jun 14, 2010 | Computers & Internet
How can I connect my P.A. system to pur phone system? cheaply easy Phone is NEAX PBX P.A. system is basic pre-amp output (analog)
This is very tricky unless your phone system has an analog audio line input provision. It's almost impossible to introduce external audio ( from your P.A. system ) into the phone system when a phone is on hold unless the PBX system has an external audio line input. If it does, all you need is a standard 600 ohm to 600 ohm audio transformer where you connect your P.A. systems preamp signal out to one side of the transformer and the other side of the transformer to your PBX systems external audio ON-HOLD line input.
Aug 31, 2009 | Audio Players & Recorders
Motherboard having a system password , idonot know what is its pa
Open the case and look for a jumper switch (usually blue or black color) labeled CLRTC or CRL. A jumper switch is a small connector connecting two pins on the motherboard. Same like the one in CD ROM drive or hard drive for selecting master or slave.
If you find it, unplug the power cable, remove the jumper. Wait 10 - 15 seconds, then put it back. Plug the power cable and try power up your computer.
Dec 25, 2008 | Dell Dimension 2400 PC Desktop
Acer Travelmate 2400
Have you tried a dongle? Also, do you have the software installed correctly (check in the control panel/system/device manager). It maybe either or both of these. You may have a damaged bluetooth connection so if you have all the drivers correctly installed then a dongle would be the only other option as far as i'm aware
Mar 05, 2008 | Acer TravelMate 2300 Notebook
Instruction Manual
check out http://www.ia.nrcs.usda.gov/Technical/gis/pda.html go down the page to the cassioppeia 2400 section et lioa la (or some such stupid saying in french)
May 30, 2007 | Casio Cassiopeia PA-2400W
Gear One PA2400 / Kustom KPC15 PA Package Logo
111 people viewed this question
Top Gear One Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Gear One Audio Player and Recorder Expert? Answer questions, earn points and help others
