Question about LG 50 50PW350 50 3D Plasma TV
50PW350 won't turn on
Started to make a clicking sound recently and now won't go on.
Lg plasma turning on then off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 28, 2016 | LG Electronics 50PW350 50" 3D 720p Plasma...
Where is the fuse for lg 50pw350
It can be located at its main power regulator board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 07, 2014 | LG 50 50PW350 50 3D Plasma TV
Is there a fuse for lg 50pw350
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time; especially to Plasma TVs.
50PW350 won't go on
Are you comfortable working with the high voltage innards of a plasma TV, including the use of a Multimeter, Soldering iron or gun, and electrical safety? If so, you will have to inspect the insides and look first at basic items such as the fuses, but continue diagnostics from there to all components, using care not to electrocute yourself. If you are not comfortable with such a thing, then professional repair or replacement of the unit is recommended. LCD televisions do not have such high voltage driver issues and do not suffer from burn in like plasma screens do, plus use substantially less electricity.
In either case, the symptoms you describe tend to come from dirty line power, so the acquisition of a UPS (Uninterruptible Power Supply) that will perform Automatic Voltage Regulation is highly recommended to scrub the A/C current and swap to battery if things get to a level that would potentially damage the TV. This kind of investment can increase the life of A/V equipment by twice or more.
Mar 28, 2014 | LG 50 50PW350 50 3D Plasma TV
There are no user serviceable parts on these flat panel tvs.
Use your warranty if available. This is why buying the extended warranty on expensive electronics is a good policy.
Find a nearby electronics repair shop and get it checked over.
My treadmill is locked in the max incline position and controls won't respond
Run the software calibration for diagnose, troubleshooting, and fix it.
2) clean the gear and shaft from elevation motor.
3) adjust the POT for better improvement.
see the diagram
God bless you
Jul 27, 2012 | Exercise & Fitness
I don't know what is wrong with my car the belt just recently broke and we had to replace it but before we did that the battery died when we were driving and we killed the battery trying to get the car...
sounds like it may be a bad alternator. jump start the car and if it gets going disconnect the negative battery cable and if it dies you have a bad alternator. It may die as soon as you unplug the jump start cables.
Jul 28, 2011 | 1997 Nissan 200SX
Gateway laptop speakers
Problems of this kind CAN be caused by a driver that has been scrambled by Windows.
Try the following, it may not help but won’t get you in any worse condition than the one you are in.
- Open the Control Panel
- Select System
- Click on the Hardware tab
- Select Device Manager
- Find and open Sound, Video and Game controllers
- Find the driver (check manual) used with your audio system and delete it (remove)
Reboot your system and, if there is nothing else amiss, it will ‘find’ a 'new' device and re-install the software controlling your on-board audio.
If this doesn’t help, then you are likely dealing with a hardware problem that only Gateway can (at excessive cost) ‘cure’ by replacing the main board.
Mar 28, 2008 | Computers & Internet
LG 50 50PW350 50 3D Plasma TV Logo
24 people viewed this question
Computer Repairing
Computer Repairing
