Question about GE JGRP20 Gas Single Oven
Oven shuts off by itself
My GE JGRP20 gas wall oven periodically shuts off by itself now.  I purchased it in October of 2004.  This doesn't happen every time, but it's happening more often.  Could it be a bad thermostat?  How could I tell?
Thanks, Alan
  • alant1 Oct 31, 2007
    How can I check my ignitor or oven valve?
    Thanks.
  • 100 Answers
When your oven reaches the desired temp. it shuts down then turns back on again after it cools down a couple of degrees and cycles like this during the complete baking cycle. If your ignitor or oven valve is getting weak it would cause this symptom.
Posted on Oct 31, 2007
  • Mike Kaiser Oct 31, 2007
    if the ignitor draws 3.2 amps or more replace the valve if less than 3.2 replace ignitor
Error code f3
F3
or
F4
Open or shorted oven temperature sensor
(RTD) Check sensor harness and harness connection between
oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is
ok.
Dec 16, 2010 | GE JGRP20 Gas Single Oven
I have never used a self cleaning oven.i have already put oven cleaner on the inside and let it stand for awhile is this right? god I don't want to blow up
You DO NOT use a oven cleaner with a self cleaning cycle. Wipe out the oven cleaner as instructed on the can. Oven cleaner is better than self clean cycles anyway. Most self clean cycles eventually cause oven control problems.
Oct 08, 2009 | GE JGRP20 Gas Single Oven
Where can I download instructions for replacuing ignitor (WB2X9154) in GE wall oven (model JGRP20)?
just call costumer service and they can give you instruction how to do it.or go on line at
www.GE.COM
Aug 15, 2009 | GE JGRP20 Gas Single Oven
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
Pilot heats up but gas will not come into bar with little holes in oven
Check the voltage at the oven gas valve, if you are getting 120v, then you have a bad gas valve.
Aug 08, 2007 | GE JGRP20 Gas Single Oven
GE JGRP20 Gas Single Oven Logo
753 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
