Question about Graco 6 Speed Opentop Reclining Swing Gingham
Graco swing batteries
Where do batteries go
2 Suggested Answers
  • 4533 Answers
SOURCE: My Graco baby swing isnt swinging, brand new batteries in it, its brand new..
Because it is brand new it isn't a good idea to do any tinkering or the warranty will be invalid.
I suggest as a first step to read the instruction leaflet thoroughly for any helpful troubleshooting guide or in case you missed an important instruction.
It is wise not to assume the batteries are ok even though they are new. Batteries aren't always treated well by those who transport or sell them and sometimes a battery will be rendered useless by dropping it or handling it roughly.
I suggest you clean the battery contacts with a solvent in case a wax corrosion inhibitor had been applied and then use a battery tester or another battery-powered appliance to ensure each cell is working correctly.
If each cell tests good refit them ensuring each is fitted the correct way around and after fitting the battery cover switch the swing on. If it still doesn't work find the seller's receipt and return it to the shop for exchange under the guarantee.
I strongly suggest you attend to these things when your baby is sleeping and you are properly awake and without an audience or distractions or trying to watch tv at the same time.
Posted on Feb 02, 2015
Does the Graco Duet Soothe have a fuse? Im hoping that is why this stopped working.
It has a plug. The swing also uses batteries if it's not plugged into the wall. You can also order replacement parts from Graco's Website.
If you need further help, reach me via phone at https://www.6ya.com/expert/sean_97e45db9c0ed1da4
Apr 10, 2017 | Graco Baby Gear
How do you turn off a graco open top swing?
www.gracobaby.com/instruction%20manuals/archive/152.pdf
GracoTo add time, push the time button once or twice. To turn swing off, press and hold either speed button briefly.
Jan 08, 2016 | Baby Gear
We need the base to a Graco Sweetpeace baby swing.
Under the "Add your solution or ask for clarification" window click on the camera icon to add photo.
May 25, 2012 | Graco Sweetpeace Newborn Soothing Swing...
I bought it and put new batteries in it and the music will play and i press the buttons to make it swing and it doesnt do anything. It doesnt make any noise like its trying to swing or nothing. Could that...
Graco swing motors are known for going bad, sorry. I have had no luck trying
to fix them as you tear them down and the electronics are what has gone bad.
They have a motion sensor in them along with a complicated motor to swing swivel
that if you lose a small ball that is the interface, you are doomed.
Time for a new one and if you buy one at a garage sale be sure to run it with weight in
it for at least 5 minutes. That culls out the bad motor ones!
Feb 05, 2011 | Graco Baby Gear
I bought a used Graco baby swing (I think from about 2001) and I can't fiure out the buttons. There are four - low-timer- high - music. It has 6 speeds, 15 songs, and time listed on the front. I don't...
YOU NEED THE MODEL NUMBER then follow link below
LOOK FOR THE MODEL NUMBER
  • BOUNCER On the back of the vibration unit, below the battery compartment door
  • OPENTOP™ SWING Inside the battery compartment behind the batteries
  • WIND-UP SWING On the underside of the top housing- the piece of plastic that runs across the top of the swing and is right above the baby's head
  • TRADITIONAL SWING Under swing tray
  • TRAVEL LITE™ SWING On the bottom of the contoured plastic seat
  • SWEETPEACE™ NEWBORN SOOTHING CENTER On the bottom of the seat
  • DUETSOOTHE™ SWING + ROCKER On the underside of the housing
  • DUETCONNECT™ SWING + BOUNCER On the underside of the housing
  • DUETCONNECT™ DLX SWING + BOUNCER On arm with motor hub
  • LITTLE LOUNGER™ Inside leg near Rock Lock
  • DUET ROCKER™ Backside of front plastic panel with Graco Logo
  • GLIDING SWINGS Under motor housing unit (electronics hub on right hand side of swing)
  • SIMPLE SWAY™ INFANT SWING On tubing on bottom of unit
  • COZY DUET™ SWING + ROCKER Under battery hub on back of swing
  • DREAMGLIDER™ GLIDING SWING + SLEEPER On side hub with electronics
Product Instructions Search Results
Jan 01, 2018 | Graco Toys
Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Same problema as described by other person: Graco swing will not swing with 5 month old in it. Put in new bateries everything. But when we take baby out it swings perfectly fine
Oct 19, 2010 | Graco Toys
Graco 6 Speed Opentop Reclining Swing Gingham Logo
112 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
