Question about 1992 D21 Pickup Door Mirror g65270444k Manual; door pedestal mounted, black, Passenger Side Nashville, Tennessee
1992 nissan d21 v6 3.0 pickup cylinders 4/6/1 are not burning fuel on drivers side
Cylinders 4/6/1 are not burning fuel. Help?
  • Nissan Master
  • 987 Answers
Check the coil, it might be cracked underneath.
Posted on Jan 22, 2015
Where is turn signal fuse or relay?
I't's on the left hand side above the brake pedal. Most often, Nissan uses the turn signal and hazzard flashers as one unit.
Jul 28, 2014 | 1987 Nissan Pickup
Where is turn signal fuse or relay located on 87 nissan pickup
In the fuse box,test circuit with a test light.
Hot to fix a clutch that goes all the way to the floor
Check your clutch master cylinder's fluid,it's located under hood in right corner,if low or empty,then your slave cylinder is bad and leaking,it's connected to side of transmission.Here's a link. Repair Guides Clutch Clutch Release Cylinder AutoZone com Here's the part. Duralast Clutch Slave Cylinder 12425 1992 Nissan Datsun D21 Truck 2WD 4...
Jan 14, 2014 | 1992 Nissan Pickup
High Beams
Check the fuse
Mar 28, 2013 | 1992 Nissan Pickup
1992 Nissan D21 fuel pump hanger assembly replacement
you can either buy the oem fuel pump/with the same plug or cut the square plug off and splice the wires directly to the wires going to the oval plug
Mar 27, 2013 | 1992 Nissan Pickup
Timing marks for 1992 nissan D21 SE
Here's a link to the 6 cylinder timing belt marks.Here'a a link to the 2.4 engine with timing chain.
Mar 19, 2013 | 1992 Nissan Pickup
Where is the fuel pump relay on 1987 nissan pickup truck located
FUEL PUMP RELAY 1987 Nissan/Datsun Truck D21 Truck 2WD 2.4L FI 4cyl The Fuel Pump Relay is located: Under hood, passenger side, front engine area, rear of headlight housing, mounted on upper fenderwell
Jun 25, 2012 | 1987 Nissan Pickup
What is the firing order for a 1992 nissan d21 pickup4 cylinder 2 wheel drive
Firing order is 1-3-4-2 and the distributor rotation is in a counter clockwise direction.
Mar 11, 2010 | 1992 Nissan Pickup
Where is fuel-filter on 2.4L D21 Nissan pickup?
it should be under the car close to the driver side door. if you can't see it trace it from the fuel tank it should be attached to the fuel line. if you have the repolacement in your hand you will know what you're looking for
Feb 28, 2010 | 1993 Nissan Pickup
1992 D21 Pickup Door Mirror g65270444k Manual; door pedestal mounted, black, Passenger Side Nashville, Tennessee Logo
95 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
