Question about Dacor Kitchen Ranges
Dacor m60 Need to buy module
Dacor wall oven MORD230 cont'd beeping,disconnecting power to unit did't work,error code 01 appear on display
Hello. The error means there is a shorted key on the keypad. The part number you will need is 701044-02, called "membrane panel assembly, black". The main board, if needed, is 101991, called LED display module. Hope I helped you!
Aug 21, 2015 | Dacor Ovens
My Dacor PGM365-01 main burner continues to spark after I place a pot or pan over it. I just replaced the spark module - still happening. Valve? Micro-switch? Clean the burner?
What is your altitude?I have the same problem and was told by Dacor that I should have the high altitude version. I'm at 5000'
Feb 14, 2015 | Dacor Cooktops
I need to by a new reomte for my Sharp TV 19H-M60 My old one is beyond repair Please let me know how to obtain one Thank YOu Joann
Hello
Just buy one "Comcast Ondemand Custom DVR 3 device Universal Remote control". Sharp Tv is listed in its manual. Codes are 10093, 10165, 10386, 11602. Proceedings for setup will be there with its manual. OK.
Jan 07, 2011 | Sharp 19H-M60 TV
I have a Dacor electric ceran topped cooktop, model ECC46S. One of the ceran glass tops is cracked badly. I have searched everywhere for either a complete module, EM4LFB with no results. I probably...
Sorry to read about your problem, I hope this helps you out.
you might want a new unit, glass replacement will cost from $600.00 to $900.00 and thats just for the glass
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Dacor Cooktops
My Dacor PGM365 knobs keep breaking off and I can't find a place to get replacements. do you know of a source?
http://www.reliableparts.com/ - DACOR refuses to fix the fundamental quality issues with the knobs. I've replaced a dozen in the past few years. I will never buy Dacor again because of the customer support refusing to acknowledge the issue.
Jul 20, 2010 | Dacor 36 in.PGM365 Gas Cooktop
Can't find an M60 17" screen replacement. Where do you get one?
Hi there please click on the click and you can buy your Dell M60 17" screen.
LINK - click here.
Thanks.
Feb 10, 2010 | Dell Precision M60 Notebook
Kitchen Ranges Logo
24 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
240cpa
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
