Question about Sewing Machines
I have a an IBM touch pad lap top computer, when I try to get on the internet is tell me I have to insert a intel pro network CD- rom. Can I download one of those
Need to download
Euro-Pro # 361
try a new needle
try adjusting the top thread tension
make sure the bobbin is inserted correcty in the bobbin case
also possible that the machine could be out of time & would need to be serviced
Mar 16, 2012 | Euro-Pro Sewing Machines
Main thread keeps breaking during sewing
here are some suggestions
try rethreading the machine
check the top thread tension
the needle is bent or blunt
the needle is inserted incorrectly
the needle & thread are not compatable---here's a tip how to tell
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Oct 17, 2010 | Euro-Pro Fast and Easy 420 Mechanical...
I just got a new computer with windows 7 in it. When i try to install the 3D software it doesn't work with windows 7. what can i do to get my program to work. When i install it it causes some of my...
3D can be made to work with Windows 7 - I have it working just fine on my 64-bit Win.7. Go to http://www.sewmuch4retirement.com/tips.html
Tip No.4 from the top is for you - these are the instructions I followed and they worked perfectly. You do need to be sure you have the latest version of 3D - it's 7.25 I believe.
Sep 16, 2010 | Husqvarna Designer I
Needle won't grab thread from bobbin
Sometimes you have inserted the needle wrong, make sure that the needle faces the rear, if that is not it, try a new needle. Make sure that you have threaded the bobbin right, by your manual, and have at least a 6 inch tail, hold your top thread and move your handwheel towards you, not away from you and it will grab the thread. If any questions go to euro-pro.com
Sep 06, 2010 | Euro-Pro 9130 Sewing Machine
I purchased a CD Rom embroidery which had the usual formats on its cover, including art. which is what I need. I could open the CD on my computer, but when I tried to send it to my Artista 180, it told me...
How did you try to transfer the ART design to your 180? It needs Artlink by Bernina to do so or the Bernina Designer program. There are different ART versions and as I know, only the Designer can convert it to the version that your model can handle. I also own some CDs and never had any problem transferring any to a Personal Design card or stitching them out with my Bernina 165.
Apr 05, 2010 | Bernina Artista 180
Machine won't sew at all
RE: Euro-Pro 9000 Mechanical Sewing Machine "Won't Sew"
I am wondering if you tried unplugging it for at least 1 minute to let it reset the onboard computer (sometimes they need to be unplugged overnight).
Try the following links....
FAQ @ http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
Manual @ http://www.euro-pro.com/europro/manuals/9000.pdf
Customer Service @ http://www.euro-pro.com/europro/feedback.aspx
Let me know if I can assist further!
jackiaria
Feb 28, 2009 | Euro-Pro 9000 Mechanical Sewing Machine
Access key code for Futura software for my CE 200
there is a insert in your cd case on the back of there it will say access code plesse get back with me with this number and i will tell you if it is the right one.
Dec 29, 2008 | Singer CE-200 Quantum Futura Computerized...
Elna Pro 5 DC
Yes I have one, can you tell me where can I get parts for my Elna Pro 5 DC?
Nov 01, 2008 | Elna 1010
Cannot get Janome 10001 to read via USB direct link from computer
You need to have Customizer og Digitizer pro to send design by cable to you MC10001.
You can also use a PCMCIA adapter in your MC10001 and a CF memorycard..you also need a memorycard reader to write to your CF card from your computer
Dec 28, 2007 | Janome Memory Craft 10000
Sewing Machines Logo
10 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
