Question about Homedics PC-400 Pro Clipper
By new blades
Old clippers need to order new blades
Wahl clippers
Teresa you lost the guide?! You cannot afford to buy a new one at $22-29 dollars! They are OLD?! Guess what? You just answered your own question. Go to WalMart, Break down and buy new ones. Don't take them apart unless your seated and have a magnet near you! By the way a New Guide will cost you $12 dollars with a blade. They come in sets only. So $12 old one $22 new one? Duh I wonder what I will do?
Jan 19, 2014 | Wahl Clipper Corp. Adjustable 10-15-30...
I just recieved a new Oster Golden A5 single speed from Amazon. The clippers worked fine with the no. 10 blade that was mounted on clipper. I removed the blade and now I can't get it back on or the 4f...
ok the blade latch only holds the blade into place.
the hinge assembly which the latch sits behind needs to be open, there is a silver piece with two ridges on, place a flat bladed screwdriver behind the hinge and this will lever open you can then slot the blade onto the hinge and close shut with the clipper running.
Jul 15, 2011 | Oster 78950-100
Oster a5 clipper not cutting,blades are new,a5 is new,2 days old
make sure the blades are connecting to your clippers turn the clipper on and attatch the blade they should click into place and should not pull off untill the release latch is depressed.
Aug 08, 2010 | Oster 76076-010 Hair Trimmer
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
My A5 clipper is not clipping at all.
If the blade mover is going when you turn the clipper on than all you need to do is take the blades apart and clean them well with a Oster spray and then oil them. I would recommend cool lube.
May 12, 2009 | Oster Golden A5 1-Speed Universal Motor...
A rattle problem with my Oster Golden A5 Clipper!
The screws on the side of the housing don't serve any purpose other than keeping the brush and spring in the clipper. You can send your blade in for realignment or call 800-830-3678(factory service) and they will help you with all your issues.
Apr 13, 2009 | Oster Golden A5 2-Speed Universal Motor...
Replacement blade
GO ON LINE YOU SHOULD BE ABLE TO ORDER THEM FROM VIDAL SASSOON.
Mar 15, 2009 | Vidal Sassoon VSCL900T2 Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Wahl clippers
Contact a scisor sharpener in your area. They usually do clipper blades as well ..
Oct 04, 2007 | Health & Beauty
Homedics PC-400 Pro Clipper Logo
Top Homedics Health & Beauty Experts
Jim London
Jim London
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
