Question about Tefal Kitchen Appliances - Others
Free mechanic advice
Getting a wire burning smell from the toaster. We need a mechanic. Call- Prof Ghosh, 9831134870
  • kakima Mar 29, 2014
    What make and model toaster? What country are you in?
  • Lipi Ghosh
    Lipi Ghosh Mar 29, 2014
    It is a Tefal make toaster. I am in kolkata, India
3 Suggested Answers
SOURCE: toaster malfunction
try adjusting the screw on the bottom of the toaster
Posted on Oct 21, 2008
  • 25 Answers
SOURCE: tp 409 smells burn when turn it on
I would advise checking the elements as well. It is possible that plastic has melted onto the elements. Try to Identify which slot the smell is strongest. If there is a spot where the elements do have some sort of foreign material melted to them, you may need to replace them.
I
Posted on Apr 18, 2009
Car dashboard lights wont turn on and smell of burning wires
If you're smelling insulation burning - STOP. Fuses should be blowing before insulation melts / burns.
Have the car checked my a trusted mechanic before using anything in the car that makes the wiring burn or melt.
Apr 16, 2014 | 2001 Ford Taurus
Engine shaped light comes on, smell of burning inside car
The "engine light thing" or check engine light is a light that tells the driver through the vehicles computer that there in most cases is a sensor problem and yes in most cases it has to do with emissions. Your vehicles computer will store a code which helps lead the mechanic in the direction as to where the problem is. I'm not sure of your location but you can take it to your local auto parts store and the will plug your vehicle in to a computer to pull the code(s) to help narrow down where the problem is. I'm not there as to what you are smelling as far as what is burning but it could be wiring or a leak of some sort in the engine compartment that you may be smelling inside the vehicle. Lets just say it is a wire that is shorted or burning. The code that is pulled should lead the mechanic to the general area as to where the short is located. In any case gettting the diagnostic trouble codes pulled is a start to finding the source of the problem. At this point until I can get a code I can't help you much as to the direction to go but hope I was able to clear up what the engine light is telling you. If you get a code(s) feel free to comment or reply here or you can email me directly at csautomotivecars@att.net and I will be happy to help you understand what the code means and maybe what you can do about it but will need the make, model, year and engine size of your vehicle. Don't worry the help won't cost you anything and I may just be able to give you a description depending on what the code is. Hope I was able to help
Jan 16, 2012 | Cars & Trucks
My 2005 Merc C200 CDI SE Coupe Sport has an occasional burning smell inside the car. There are no warning lights and I cannot find anything under the hood.This has happened three times in as many weeks...
Well if you had me as a passenger you wouldnt smell nothing ,cars never play up when i get in them for some strange reason ,To be honest ask a local mechanic to use the car for a couple of days so with a bit of luck it will happen when hes driving it and as soon as he smells it he will know what it is ,it could be antifreeze ,radio ,wires, plastic on exhaust down pipe ,anything in fact have you had a new exhaust fitted recently ,are cats getting in somewhere ?? very difficult to point you in the right direction sorry
Dec 27, 2010 | Mercedes-Benz C-Class Cars & Trucks
Dualit lite 4 slice not working
It can be repaired. There is a short circuit inside may be of dust gathering on contacts or the contacts are worn out due to prolonged use thus touching the heating coil or body some where inside. Smell coming is definitely burning of wires inside. Open the toaster and you may be able to see the burning spot
Jan 09, 2010 | Dualit Lite 4 Slots 4-Slice Toaster
I have a burning smell when i turn it on
what you have to determine is if the burning is something on the element .
Eve4n dust will create a burning odour.
Sep 17, 2009 | Rival TO606 1500 Watts Toaster Oven with...
Bad chemical smell coming from the new Kenmore toaster.
I would say return the toaster. No telling what kind of fumes would get into your toast -- toasted bread is like charcoal -- it'll absorb a lot of stuff.
I agree with the China/USA sentiment.
Apr 21, 2009 | Kitchen Appliances - Others
Tp 409 smells burn when turn it on
I
Mar 08, 2009 | Toastmaster TP409 4-Slice Toaster
2004 Suzuki Forenza-- flashing check engine light, hesitation
Go to library and get an automechanic's Diagnostic and Repair book or manual.
Simply check out the possibility whether the negative response that you are getting from your car matches the mechanical data found in the repair book and manual.
AND NEVER forget to consult an attorney for FREE advice concerning laws governing the legal responsibilities of auto mechanics (there are attorneys who do NOT charge a fee for the first 30 minutes of advice) Check yellow pages. GOOD LUCK!
Feb 22, 2009 | 2004 Suzuki Forenza
Odor from toaster
ozone smells like fresh sweet air ( same smell as after a lightning strike )
what you probably have is the smell of melting plastic from wires in the toaster
Apr 06, 2017 | Kenmore KTES4 4-Slice Toaster
Toaster malfunction
Sep 09, 2008 | Sunbeam Kitchen Appliances - Others
Kitchen Appliances - Others Logo
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
