Question about Pegasus Technologies ST09 TV
Need new antenna
Need a new antenna
Need to replace radio antenna on a 99 isuzu rodeo
I just replaced the antenna on our 02 rodeo. No need to remove radio or anything in dash. This is how I did it.
First you will need access to back of fender, enough room for your hand. Open hood and remove 3 bolts running along top of fender, open passenger door and remove top bolt holding fender. Gently pry top of fender away from vehicle. Place object in gap to hold fender ( I used the head of a rubber mallet). Reach inside fender and disconnect old antenna, follow cable through wall into passenger compartment. Gently pull cable from behind carpet and unplug old antenna from coupler. Connect new antenna to fender ( replacement antenna I ordered was slightly smaller than opening so I had to add washer). Run new antenna cable through wall and plug into coupler. Re-attach fender
Aug 23, 2012 | 1999 Isuzu Rodeo
Changing AM / Fm radio antenna on 2006 chevy silverado. bought new antenna and it came with short pigtail. where does it plug into. Thanks
Aftermarket antennas come with notoriously short leads. What you need to do is remove the stock antenna and compare lengths to the replacement. The difference is the length of extension you'll need to get from your local electronics supply or auto parts store. The stock antenna plugs into the back of the stereo itself.When you route the new lead, try to follow the original location as best as possible.
Good luck!!
Nov 16, 2010 | Car Audio & Video
Will not transmit.
if this radio is new, return it. Its garbage. Its the worst CB cobra ever made, and one of the most hated.
Still people should hear you. Have you calibrated your antenna for best SWR?
Look in your manual. Read the section on SWR. The antenna needs to be tuned, or your RF energy is not going out of the antenna, and being reflected back into the radio. That's bad.
And its "Coax" Not co-aux.
Jul 28, 2010 | Cobra 18 WX ST II 40-Channels Base CB...
What type of antenna do you reccomend cant get the tv to work at all no picture no sound not using cable no antenna tried auto PLEASE ADVISE!!!!!!!!!!!!!
Lets get started. First the TV you have does not have the new ATSC digital tuner built in. It uses the old NTSC tuner. You might find a few stations, however most major networks have gone Digital because the maximum power for NTSC is limited to 1000 watts. ATSC is the new digital standard for broadcasting both High Definition programs as well as standard definitions programs. So you will need a Digital converter box. They sell them at Radio Shack for around $60. You can get one on ebay for around $25. You will also need and antenna. A good old set of rabbit ears will work fine if you not to far (less than 25 miles) from the transmission towers. If your out in a rural area (greater than 25 miles from the tower) you may want to consider and outdoor antenna. Antennas Direct is a great source for antennas.
http://www.antennasdirect.com/
You can also get help estimating what kind of antenna you need at this web site:
http://www.antennaweb.org/aw/Address.aspx
However you may want to consider buying a new TV which will have a new ATSC tuner built in. You will still need and antenna.
Hope this helps.
Feb 23, 2010 | Philips 25TR19C 25" TV
Replace antenna
Remove old Antenna
  1. Activate the antenna switch to the up position.
  2. Using the wrench or needle-nose pliers, loosen and remove the original retaining nut on the base of the antenna mast.
  3. Gain access to the underside of the area of the trunk where the antenna is located.
  4. Remove the bracket or brace that is below the hole and holding the antenna in place.
  5. Remove the mast.
  6. Find the motor that controls the antenna mast. Generally, power antennas will have a constant 12-volt lead and a ground lead. The ground lead will be grounded to the panel next to the motor.
  7. Remove the ground lead from the panel.
  8. Pull out the antenna coaxial cable.
  9. Unplug the coaxial from the extension coaxial cable.
  10. Remove the original antenna coaxial cable. Note the route the cable follows.
Install new Antenna
  1. Inspect the fender area where the antenna mast will be mounted for rust.
  2. Clean the area before installing the new antenna.
  3. Plug the new antenna coaxial cable to the extension coaxial cable.
  4. Plug the new antenna's coaxial cable into the radio's chassis antenna jack if there is no extension coaxial cable. Tie or tape the string you put on the extension cable to the new antenna coaxial cable. This assures that the 2 cables stay together as you route them to the antenna mount in the fender.
  5. Connect the power lead of the antenna to the power antenna lead on the radio.
  6. Connect the 12-volt constant lead to the antenna to a 12-volt source or to the ignition switch.
  7. Direct the new antenna cable via the same route followed by the original antenna cable on up to the hole in the fender in which the mast will be mounted.
  8. Ground the ground lead from the motor to a clean metal surface on the metal panel near the mount.
  9. Insert the mast into the hole. Face the serrated side of the plastic cable on the bottom of the mast toward the motor side. The plastic cable can be inserted freely to about 12 inches and will stop.
  10. Turn on antenna switch to down position until the plastic cable goes down and catches into the gear mechanism of the drum housing. If the plastic cable does not gear into the mechanism, twist the cable slightly until the cable contacts into the gear mechanism while the motor is in operation.
  11. Stop the motor after the cable goes into the housing 12 to 25 inches.
  12. Secure the bracket or strap to the bottom of the antenna mast and to the metal fender.
  13. Replace the retainer nut to the base of the antenna mast and secure tightly.
  14. Replace the panel that covers the antenna mount area.
Oct 16, 2009 | 1996 Honda Accord
Power antenna broke and I need to replace it. How
Buy replacement antenna mast. Remove old one by unscrewing the retaining cap nut. Turn on the radio & let the antenna cable run all the way up while you pull on it to remove it.
Install the new antenna mast by turning the radio 'off' so the spool inside goes back to its beginning while you feed the cable of the new antenna down into the antenna mast hole.
Once the cable is all the way down, reinstall the retaining nut/cap and turn on the radio to allow the spool to run the antenna 'UP.'... cycle the radio ON and then OFF several times allowing the antenna to move all the way up and all the way down.
That's it!
Sep 28, 2009 | 2001 Hyundai Sonata
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Antenna replacement
There should be a nut at the base of the antenna or in the car right under the antenna. take that off. then there might be two ways to do it. 1. you might have to run new antenna wire to under the dash board. or the antenna will need the adapter right under where the antenna sits.
Jun 20, 2008 | 1997 Nissan.5 Altima
Install a new antenna i850 nextel phone
ok you will need a hex screw driver, remove the old antenna by removing a little black cover on the antenna which hides the screw. remove it, insert the old and remove the screw cover and screw it back in.
Oct 29, 2007 | Nextel i850
Pegasus Technologies ST09 TV Logo
27 people viewed this question
Top Pegasus Technologies Televison & Video Experts
Electro Med Services...
Are you a Pegasus Technologies Televison and Video Expert? Answer questions, earn points and help others
