Question about Nuby 2-Pack 10 oz. Flip-and-Tip Hard Straw Cup
Locking my nuby sippy cup
Cup keeps spilling
Will not puncture a hole in the k-cup just comes out as hot water?
Mine was doing this too. You need to tilt the basket so that the blade device hangs toward the center of the basket and you can guide it into the bottom of the K-Cup. (It will be on the edge, but the blade enters from the bottom.) Then push the cup on down on top of the blade and it will make a hole so the coffee can drain out of the cup. I was afraid grounds would spill out but there is a filter that keeps that from happening. I was ready to throw the machine out before I figured this out!
Feb 10, 2016 | Hamilton Beach 49995 FlexBrew Single Serve...
Replacing cup holder
I assume you mean the one that flips up in the center console?
If so, there are three likely issues.
1) did you slide out the retainer from the upper screw? the top screw had a cover that had to be pried off. you then took the screw out. Lastly you have to slide out the plastic retainer that the screw went into. It slides out towards the opening.
2) you have to have the cup holder partially open to remove it. the hinged part that folds up is stored in the cavity under the console when closed. you have to open the cup holder and keep pushing until the front of the cup holder lip comes up. Work the cup holder up and down until it comes out.
3) the cup holder is stuck in place due to years of spilled liquid. If you've done the above, then you can either spray soapy water on the creases around the opening and let it set, or you can apply strategic brute force.
Be aware through. if this is the center console cup holder just behind the gear shifter. There are two screws and nothing else to hold it in. Just be carefull....
Mar 17, 2014 | Volvo S80 Cars & Trucks
Water will not suck out of my son's sippy cup (Dr. Browns hard spout).
there is a hair problem. it is not getting air to replace the liquid.
look for blockage
Aug 22, 2013 | Dr Brown Soft Hard Spout Training Sippy...
I put my kids two plastic cups and two swrily straws in the dish washer and when I went to go use them that is what happen to then they unswriled and will not fit in cup
Option 1: Deluxe Refurbishing
  1. Get some stiff pipe-cleaners from the craft store. You may need to braid them together to end up with one that's thick and strong enough to use.
  2. Boil a few litres of water.
  3. Lower the straws into the boiling water. They'll soften and uncoil.
  4. Using tongs and wearing water-proof and heat-resistant gloves, pull the straw out of the water.
  5. Feed the straight straw over the pipe-cleaner.
  6. While the straw is still hot and soft, coil it around the outside of the cup. This is your first pass. When the straw sets, take it off the cup.
  7. Put the straw back in the boiling water. The pipe-cleaner should hold it in the correct (roughly correct) shape.
  8. Set the cup on a low pan, like a bake-tray. This is to catch spills. DO NOT SKIP THIS STEP!
  9. Push the softened, coiled straw into the cup, twisting the straw to tighten the coil. You may use tongs or a butter-knife to push the straw down in the cup.
  10. If the straw gets stuck, and starts to set, fill the cup with boiling water. BE VERY CAREFUL. Pour the water back into the kettle or pot, then keep working the straw into the correct shape.
When all of this is done, you can pull the pipe-cleaners out of the straw. Voila! And if you're feeling daring, you can use this method to create a completely different shape to the straw. If you do, keep the pipe-cleaners handy. You'll need them to clean the interior of the straw (it gets gross otherwise).
Option 2: Quick and Dirty Refurb
Boil the water, heat the straw, and put the cup on the bake-tray.Fill the cup with boiling water.Push the floppy straw into the cup, twisting it into a coil as you do so. You may use a dull knife to arrange the coil of the straw.
The coil will be pushed to the bottom of the cup, and won't have the nicely separated spiral of the original - but it will work.
Jan 01, 2013 | Toys
Water does not go through the k cup. when the cup is placed in the coffee maker and the lid is dropped down, the needles punch through the cup at the top and the bottom. the water spills over the top of...
Yup... the bottom needle is plugged...Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 24, 2011 | Keurig B60 Coffee Maker
Baby hit keyboard with sippy cup, a little milk spilled on the keyboard, cleaned immediatly but some keys are sticking or crossed ex: y is sometimes 3 or both at the same time. how do i access the...
Desk top or laptop? Either way a new keyboard is not that much. I'd really consider buying a new one.
Hope this information will help.
Your response is very much appreciated...Thank you for using Fixya...
Sep 23, 2011 | Toshiba Satellite A135-S2276 Notebook
Munchkin sippy cup - too difficult to sip!!!!
is there a rubber stopper that may be put in wrong try taking it out and putting it in the other way
Apr 03, 2009 | Munchkin Magic Cube - Mozart
Nuby 2-Pack 10 oz. Flip-and-Tip Hard Straw Cup Logo
65 people viewed this question
Top Nuby Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Nuby Baby Gear Expert? Answer questions, earn points and help others
