Question about Insignia Televison & Video
Need the nut for the bolt that holds the strand on
Need nut for the stand
3 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Problem installing new toilet bolt covers.
unthread the nut as far as possible, then tighten it one full turn. Cut off the top with a hacksaw or dremel grinder and re-try. The bolts are cheap. A small jewelers file may help. Look for the damaged thread and remove the burr.
Posted on Dec 22, 2008
  • 521 Answers
SOURCE: is there a lock nut holding the caliper bolts on a
its not a lock nut. Some cars have the retainer bolt screw into the slider pin. You will need a second wrnch to hold the slider pin as you unscrew the retainer bolts.
Posted on Jul 17, 2009
Replace front brake pads
1. Raise vehicle
2. Support on jack stand
3. Remove lug nuts
4. Remove wheel
5. Remove bolts holding caliper
6. Remove calipers
7. Remove brake pads
8. Push piston into caliper
9. Inspection rotor for damage if damaged replace
10. Install new pads
11a. Replace caliper on rotor
11 b. Replace bolts in caliper and tighten
12. Bleed brakes
13. Replace wheel
14. Replace lug nuts
15. Lower vehicle
16. Tighten lug nuts
17. Test drive vehicle
Oct 17, 2015 | 2004 Chrysler Sebring
Tip
How to Replace Brakes on a Mercedes-Benz E320?
1) To replace the brakes in your car you need to turn the lug nuts for all the wheels.
2) You will have to turn it one-quarter counter clockwise with the help of tire wrench tool.
3) For this procedure the car needs to be lifted to a height. So Turn off the key, raise the car and support it with jack stands. Lift both the front and the rear of the car.
4) After that remove the lug nuts and wheels carefully.
5) Now above the brake assembly you will see the bolts holding caliper mounting. Remove the bolts. This will loosen the brake pads .so remove the brake pads carefully.
6) Insert the new brake pads and reassemble the brake caliper assembly. Assembly is the reverse of dis-assembly.
7) Refit all the parts properly which you removed while removing the old brake out.
8) Fit all the bolts carefully to their respective positions.
9) Fix the wheels and lug nuts. Tighten the bolts properly.
10) Then Lower the Mercedes to the ground from jack stands carefully.
11) Then turn the car ON and check the pressure on the brake system by applying the brakes.
on May 21, 2010 | Mercedes-Benz E320 Cars & Trucks
Is the compensating nut right or left hand threads?
Hi Corbin, they are regular right-hand threads. If you are having trouble breaking loose the bolt nut, it could be because there is an excessive amount of red Loctite. Hold a propane torch on the nut for a couple of minutes to melt the Loctite then use a 3 ft pipe as an extension on your breaker bar to loosen the nut after you install a wedge of soft metal ( aluminum or brass ) or a piece of hard wood in between the top strand of the primary chain and the compensating sprocket. When reinstalling use a few drops of red Loctite and torque the bolt nut to 165 ft lbs. and for more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day. Harley Davidson Manuals Mark Workshop
Sep 10, 2015 | Harley Davidson FXDWG Dyna Wide Glide...
2003 TL. How do I remove the oil pan?
Not too hard if it is a southern car, if it's from the north, a bit more effort might be needed because the nuts on the exhaust rust. If you are working on the ground, get it up high on ramps or jack stands. Always put another support under the car. Leave the floor jack in place and use jack stands, slide something, like the front tires, under the car, too. NEVER work under a car without a backup support. Cars can, and do, fall off jack stands.
1st you have to remove the exhaust "A" pipe. 3 nuts, 14mm on each exhaust manifold need to come off. ALWAYS spray a penetrating lube, like WD40, on any exhaust nuts before loosening, and before installing them. You need a really good socket, extension and a breaker bar, make sure the socket is on the nuts correctly, break them loose without rounding them off. Then two 12mm nuts on the support bracket, and 3 14mm nuts at the outlet of the "A" pipe at the converter. If these last 3 are too rusty, you can unhook the exhaust hangers and move the assembly over. (Leave the back muffler hangers on.) Drain the oil. (I always try and do these jobs when an oil change is due) two 14mm bolts going from the oil pan to the transmission, and a 10mm bolt holding an access plate at the transmission end, remove access plate. Now a bunch of 10mm bolts and nut holding the oil pan in place. You might have to pry the pan loose, a big drift works good. There are a couple of spots to hook onto and pry.
Jun 08, 2015 | Acura TL Cars & Trucks
How to remove an alternator from a 2001 dodge intrepid 2.7l
  • Unhook the battery. Remove the negative cable first, then the positive one.
  • 2
    Lift the front end of the car, using the jack, and place it on jack stands. Refer to your owner's manual for a placement diagram--they are in an unusual location for the 2001 Dodge Intrepid.
  • 3
    Remove the plastic splash guard from the underside of the engine. It is held in place by several bolts.
  • 4
    Unbolt the transmission cooler, then move it out of the way. Don't remove the hoses--just the bolts.
  • 5
    Remove the brace that holds up the radiator. Use a jack stand to hold up the radiator.
  • 6
    Loosen the adjustment T-bolt and pivot bolt on the alternator, but don't remove them. Remove the belt.
  • 7
    Unscrew the nut that holds the battery cable to the alternator, then remove the cable. Unplug the other electrical connector, as well.
  • 8
    Unbolt and remove the alternator.
  • 9
    Replace the alternator. The steps are the reverse of the removal procedure. Torque the nut on the battery cable to 90 in-lb. Torque the mounting and pivot bolts to 40 ft. lb.
  • Mar 17, 2011 | 2001 Dodge Intrepid
    How do you replace ball joints
    Removing the Ball Joint Step 1 Loosen the lug nuts on the front wheel assembly with the ball joint you need to replace. Do not remove the lug nuts.
    Step 2 Set the transmission in neutral (manual) or park (automatic) and raise the wheel off the ground using a floor jack. Then support the car on a jack stand.
    Step 3 Chock the rear wheels and apply the parking brake.
    Step 4 Remove the wheel lugs and the wheel assembly.
    Step 5 Remove the mounting nut and dished washer that secure the stabilizer bar to the control arm. Use a wrench or ratchet and socket.
    Step 6 Unscrew and remove the mounting bolt and nut holding the inner side of the control arm to the car's body. This will relieve the tension on the stabilizer bar. Use a wrench to hold the mounting bolt as you unscrew the nut with a wrench or ratchet and socket.
    Step 7 Unscrew the bolt on the steering knuckle that holds the control-arm ball joint to the knuckle. Use a wrench or ratchet and socket.
    Step 8 Spread the steering knuckle joint that holds the control-arm ball joint to the knuckle. Use a large screwdriver or pry bar. Then separate the ball joint from the steering knuckle.
    Step 9 Pull the control arm from the stabilizer bar.
    Step 10 Remove the stabilizer bar spacer from the control arm and keep it in a secure place. You will need to use it on the new control-arm ball joint assembly.
    Installing the Ball Joint Step 1 Insert the new control-arm ball joint stud into the steering knuckle joint. As you look through the mounting bolt hole on the steering knuckle, align the notch on the ball joint stud with the hole. Insert a new ball joint mounting bolt and start a new nut on the bolt. Tighten the nut.
    Step 2 Mount the stabilizer bar spacer in the control arm, then insert the stud bolt at the end of the stabilizer bar into the control arm mounting hole and spacer.
    Step 3 Set the other end of the control arm in its mounting position and insert the mounting bolt. Then start the mounting nut on the bolt by hand.
    Step 4 Hold the head of the mounting bolt that secures the control arm to the car's body using a wrench, then tighten the nut.
    Step 5 Secure the stabilizer bar to the control arm with the dished washer and mounting nut. Tighten the nut.
    Step 6 Install the wheel assembly and lugs. Tighten the lugs with the lug wrench just enough to hold the wheel assembly firmly in place.
    Step 7 Lower the vehicle and finish tightening the wheel lugs.
    Step 8
    Remove the chocks from the rear wheels.
    Aug 08, 2010 | 1998 Ford Escort
    How do you remove the rotors from a 1991 honda accord?
    Loosen both front wheel lug nuts and raise car and support on jack stands. Remove wheels and have a friend hold brake pedal down and remove axle nut. Use a chisel or screwdriver to remove stake on nut to axle edge. I use a 3/4 drive set socket and remove axle nut. Rent it from Autozone. Remove caliper assy and support with coat hanger or bungee cord to hold weight of assy off of brake hose. Remove Cotter pin and nut on lower control arm. Separate with ball joint fork and pull strut assy away to the side while pulling stub axle through and out of the way. Remove 4 bolts holding rotor and hub assy. on the inside of steering knuckle and separate. Now remove 4 bolts on hub's outer side and separate rotor and hub. You can use a bar or large screwdriver between wheel studs to loosen the 4 bolts.
    Aug 04, 2010 | 1991 Honda Accord
    When dimmer at certain position light fades and then gets brighter
    Sounds like the connections are marginal. Turn off the power, and examine the connections. They should be nice and tight with plenty of clean copper in contact. If this dimmer has stranded wire leads which are connected to solid wires with wire nuts, remove the wire nuts and take a look. If they are messy, cut off the exposed ends of all of the wires and re-strip them. Stranded wires are difficult to strip well without a wire stripping tool. The solid wires should be stripped to a length of about 1/2 inch, the stranded wires should be about 5/8 to 3/4. Now take your stranded wires and twist them like with your fingers so they resemble twisted rope. Then twist the stranded wires around the solid wires with your fingers, just once or twice around. The ends of the stranded wires should be nearly even with the ends of the solid wires. Now add the wire nuts. Twist them nice and tight by hand while holding the pair of wires together at the base of the wire nut. If you have weak fingers or the wire nuts have a fairly small outside diameter, you can use pliers to twist the nuts a little tighter. No bare wire should be visible beyond the base of the wire nut. Make sure that everything is tight by trying to pull off the wire nut and by trying to pull out each wire individually. It's also a good idea to wrap up the wire nuts and a bit of the wire with electrical tape. Good luck. Thanks for using FixYa, Al Kupchella
    Apr 21, 2010 | Leviton Decora Light Dimmer Switch
    How do you get the one bolt off to take the alternator off and replace it
    Give this to your brother in law:
    Park the car on a level surface. Turn the engine off. Open the hood and disconnect the negative terminal from the battery cable.
  • Step 2 Loosen the lug nuts on the driver's side tire. Jack the car up till the tire has left the ground, and you can get a jack stand underneath to support the For Contour's weight. Lower the car onto the jack stand and remove the jack. Remove the tire.
  • Step 3 With a socket wrench, remove the four bolts in the wheel well that hold the mud flap and the flap that protects the radiator from road debris.
  • Step 4 Loosen the belt tensioner bolt by reaching in from the top of the engine with a socket or box wrench. This bolt is usually found in the engine block, holding a spacer bar to the alternator; consult your manual for the location in your specific year of Ford Contour, as they vary. Remove the belt from the pulley.
  • Step 5 Pull the cotter pin from the ball joint stud where it connects to the wheel knuckle in the wheel well. Using a box wrench, loosen, but do not remove the nut on the stud.
  • Step 6 Attach the Tie Rod End Puller to the tie rod by placing the tie rod end in the channel on the top of the steel grip of the puller, and twist the screw clockwise until the tie rod comes free. Separate the tie rod from the wheel knuckle.
  • Step 7 Remove the nut on the ball joint stud that you loosened in Step 5.
  • Step 8 Draw, mark or photograph the way that the wires connect to the alternator and then disconnect the wires.
  • Step 9 Loosen and remove the three bolts holding the alternator in place. There will be one at the top, one at the bottom and one in the rear holding the alternator in a bracket attached to the car frame. Withdraw the alternator through the wheel well.
  • Step 10 Installation is the reverse of removal. Remember to use a new cotter pin at the nut on the ball joint stud.
  • Nov 25, 2009 | 1997 Ford Contour
    I need to replace "shocks" in tailgate.
    You need a deep 9/16 socket for the top nut, on a swivel would be great. Keep the jeep on the ground and remove the top nut first. Remove the bottom 1/2 inch nuts and bolts (2). Install in reverse order.
    Jack up the front end and place on jack stands. Place jack stands on the frame behind the front wheels. Ensure stands are not in a place where they will slip and make sure vehicle is on an even surface as you do not want the vehicle to fall off of the stands, especially while you are under it. Remove tires once vehicle has been placed on the stands. Remove the top and bottom bolts from the long tubular shock. Then remove the bolts holding the coil shocks on. Because when doing this as there may be tension in the coil springs still. Replace the shocks and reinstall the bolts. This job is fairly simple but can be intimidating if you have never done it before. You will be amazed at how easy it actually is once you have done it. Just be sure to remember how everything came apart and you will be able to get everything back together just fine. You can use the jack to adjust the axle up or down to make getting the shocks out easier. Repeat for the rear. Good luck
    Jun 17, 2009 | 1995 Jeep Grand Cherokee
    Televison & Video Logo
    11 people viewed this question
    Top Insignia Televison & Video Experts
    Jaime Hernandez
    Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
