Question about Dyson DC35 Handheld Vacuum
Fully charged no power
Light on says yes fully charged, however when press button to vacuum no power. please help
Could be a jam/blockage in the Power Head. To check, remove the Power Head and extension tube and try again. If the cleaner runs normally without the Power Head attached, then the problem is obviously in the Power Head. First step - remove the brush from the Power Head and check for jam/blockage. The rectangular hole directly behind the brush (through which the dust passes on it's way up the extension tube to the top of the cleaner) is relatively small and clogs easily (especially if you have a pet!), so you need to make sure that it is clear. If the cleaner doesn't run with the Power Head removed, then it is probably a problem with the main motor and would need more expert investigation!
Posted on Mar 29, 2014
Why does nothing happen when power button pushed?
The Dyson cords are known to go bad, test the cord and see if there is voltage. If this is too mechanical for you, please take the vacuum to your nearest vacuum repair shop
Mar 21, 2016 | Dyson DC44 Animal Handheld Vacuum Cleaner
Roomba 560 fully charges. Runs for 2 seconds fully green and just stops. And lights up red.????
Set him on the floor, after powering him off and then back on, and press the "Clean" button three times. This will reset him.
Sep 11, 2014 | iRobot Roomba 560 Robotic Vacuum
When do I know when my Shark cordless V2945Z is fully charged?
The light next to the power button will illuminate when the unit is charging and turns off once the charge is complete.
Jan 18, 2014 | Euro-Pro Shark Cordless Stick Vacuum...
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
Seems to charge but then wont come on
Sounds like you bought a defective battery
You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If it still goes red get a refund and a new one.
Mar 07, 2010 | iRobot Roomba 4105 Bagless Robotic Vacuum
Battery will not charge fully
Hello. I can assist you. You will have to take the steps to RESET the Roomba charging system. Here are the steps:
1. Remove the battery. 2. Hold down the power button for five full seconds. 3. Reinstall the battery. 4. Charge the battery until the power light is solid green AND then leave it on the charger for another 72 hours, yes 3 full days!
Here is a great link to the Roomba instructions and a video that shows you all of the steps I stated above.
Regards, Joe PS please rate my answer. Thank you and happy holidays.
Dec 23, 2009 | iRobot Roomba 4000 Bagless Robotic Vacuum
My iRobot scooba won't turn on after a full charge
Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
Jul 26, 2009 | iRobot 5800 Scooba Vacuum
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
ROOMBA 415
It could be the power button itself. If you have a Roomba remote, try using that to power on the robot.
Sep 28, 2008 | iRobot 4150 Roomba Vacuum
Dyson DC35 Handheld Vacuum Logo
349 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
