Question about Heath Zenith Designer Series Wired Plus Wireless Doorbell - Contemporary Silver Finish, DC-3344
Unit says install cover when pressed
When doorbell pressed says install cover, even when cover is on
How do I change the batteries in my Carlon RC8800R doorbell
Do you need to replace the batteries in the chime button or the receiver? To change the batteries on the doorbell (chime button) for most Carlon models, you need a ballpoint pen first to remove the chime button from the back. Press the pen point in the small round hole at the bottom of the button. Then gently push in on the tab. Finally rotate the chime button cover up and away from the back cover. Next take the ballpoint pen or a small screwdriver and place it in the slot below the top battery. Lift the battery up. Repeat this with the second battery. Then place the replacement CR2032 batteries into the battery compartment one at a time with the positive side up.
For the most of the wireless receivers, press the center of the brass tubes and lift those free to replace the 4 D cell batteries (2 behind each tube). A few models have a more obvious battery cover for a set of 4 AA cell batteries.
Many Carlon wireless chime manuals are available here: http://www.lamson-home.com/WirelessChimes.php . The direct link to the manual listed for the RC8800R is http://www.lamson-home.com/ProductSupport/WirelessChimes/RC3304_4300IM_3.06_v2.pdf .
I hope this helps.
Oct 09, 2016 | Carlon Home Security
Indoor plug in device works fine but doorbell isn't despite changing batteries.
Salutations Helen Wahlen,
If you DO NOT have a RESET procedure in the MANUAL... Remove ALL power from both units... (battery from the base ...if equipped).
Re-Plug the base unit close to where the button is mounted
and restore all batteries & power and start the INSTALL instructions from the beginning.
Failing that.. DISCLOSE what in the world we are discussing (make, model... year, etc) and we can give it more appropriate attention... (resulting in better advice),
Happy hunting!
Mar 19, 2016 | Home Security
Doorbell stopped working even after installing new batteries in unit and remote push button.
spray the contact area with a cleaner . they corrode even when we can not see any
Feb 02, 2016 | New Home Security
M&S DMC1 door bell error
I'm having the same problem did you find a fix.
May 22, 2012 | M&S Systems M S Systems Dmc1rsa Standard...
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
Hello I have now got 2 (two) of these units over the past 8 months and neither work----changed batteries--interchanged push button---changed main unit--nothing works----but when my neigbour across road has...
The doorbell buttons and your receiver must be on the same channel. If you will get out the directions that came with your unit, they will describe the process to go through to reset the specific "codes" for your buttons and receiver.
Jan 04, 2010 | Desa International White Wireless Plug In...
Wireless doorbell rings by itself
Doorbell button is sticking or slightly pressed in. Check to see if cover is installed correctly. It may be on on one side.
Aug 31, 2009 | Desa International White Wireless Plug In...
Doorbell/cartel
The cadence is different, but you can change all the other rings to a different tone. On a 76xx phone, press PROG and the CO button twice. Press your navigator button up (or down) until you hear the tone you like, then press enter to save.
Tones 01,04 and 05 tend to be reasonable.
Carl
Aug 01, 2008 | Panasonic KX-T7633 Corded Phone
Heath Zenith Designer Series Wired Plus Wireless Doorbell - Contemporary Silver Finish, DC-3344 Logo
Top Heath Zenith Home Security Experts
Mike
brian soufane
Are you a Heath Zenith Home Security Expert? Answer questions, earn points and help others
