Question about Dyson DC35 Handheld Vacuum
Dc 59 red flashing light
When a depress the trigger the light starts flashing red
How to fix my dc 62 red light keeps flashing AFTER I WASHED IT
sounds like you battery is dead. Take it to your local vac shop for diagnosis.
Feb 19, 2015 | Vacuums
Not spraying water and solution
Tanks may be empty or not properly seated.
-Fill up the bladder with hot water and the solution tank with proper cleaning liquid.
-Remove and reseat both tanks
Pump may dry, needed to prime.
-Turn "off" power wait for about minute turn "on" power and depress spray trigger.
Check and clean filter on the deck (under the clean water tank, a red slotted plastic screw)
If nothing works you have to open the deck cover and go into details: check the pump, its a 12V DC motor, the solenoid, its a valve which operates with 120V, the hoses for broken or pinched part, the diode bridge (creates about 12V DC for the pump if the vacuum motor is turned "on" and the secret fuse (3,15A under the heat-shrink series to the diode bridge, if this one goes, no power to the pump!)
Mar 09, 2014 | Bissell ProHeat Pet Upright Deep Cleaner,...
Hello, what is the significance of the lights when charging? The red and the two green lights are flashing when charging. After the time charge (1 night), the Dyson DC 16 does not function, the battery...
yes the reason the green and red light were flashing the way they are is because its a warning to you that the battery is either no longer good or there is problems with your wireing. Also those vaccumes were designed to not charge when there to cold or to hot as a saftey issue.
Aug 06, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Red light flashing constantly on dc16 when on charge, used to just stay permantly red without flashing until it went green when charged up.
I had a similar problem when I bought an after market 2Ah battery. Would stay solid red for a few seconds then flash red. I believe my problem was that the battery had gone into "sleep mode" I.e. it was discharged to the point that it "sleeps" in order to protect itself. So......I simply attached a domestic DC multi adapter to the terminals on the battery that are marked + and - (the 2 outside terminals on a DC16 Dyson battery). Switched on the DC adapter for around 10mins and this was enough to "wake" the battery. It now charges as normal attached to the DC16 in the Dyson charge mount.
For a pretty in depth article on lithium battery sleep have a look at this:
http://batteryuniversity.com/learn/article/low_voltage_cut_off
Oct 29, 2010 | Dyson DC16 Root 6 Bagless Handheld...
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Apr 01, 2010 | Vacuums
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
Hi, this is our third Dyson DC-16.. the Trigger was shorting out on the first two.. Now we have the third one for about a year.. on charge when not using it.. don't use it every day, but for quick pickups...
How are you charging your battery? Every battery has a memory. If you dont let it die the first come times then charge to full the battery will assume 40% is 100%.
Oct 23, 2009 | Dyson DC16 Root 6 Bagless Handheld...
Dyson DC35 Handheld Vacuum Logo
183 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
