Question about Octane Fitness Q35c Elliptical Cross Trainer
Octane q35c won't turn on
Won't turn on
Car won't turn off
change gas station ,,,,... you are use 92 octane
Dec 22, 2012 | 2000 Jaguar S-Type
496 mag runs rough during warmup cycle
Go up on gas octane to 89.
Jan 01, 2018 | Cars & Trucks
Zafira 1.8 petrol 03 runs rough for 30/50 seconds when started then ok but a little sluggish
The "won't rev" part sounds like a preventative so you won't destroy the engine from cold start-up. The sluggish part sounds like bad fuel or spark plugs. Where do you buy your fuel and what octane is it? and have you Changed your plugs?
Jun 25, 2012 | Cars & Trucks
2002 xj6 2.5 turns over trys to start but won't
if car has been sitting idle for a period of more than 7 days fuel looses its octane strengh/ batterry could be low test it - Make sure timing is accurate and try spray into carbaretor direct before strart with WD 40 or such like product to direct fuel feed to spark 0k
Jan 31, 2012 | 2002 Jaguar X-Type
2001 chevy malibu. I filled up with gas this morning and didn't get very far and it died. Won't start back up. What could it be?
Hello! I'm not so certain that the filling of the tank and the fact that the engine died and won't start are related...Lets get a little background...Has the car been running poorly; Or was everything in tip top shape, and after filling the tank it quit? Is the Check Engine Light on now? Any idea how many gallons you pumped in; And the octane you used? And lastly, was it an often used gas station?
Guru..............Saailer
Sep 27, 2011 | Cars & Trucks
Motor turns over won't start. Cleaned terminals, put in new battery, still won't start. Removed gas cap to vent air on hot day, still won't start. Lights all come on, all electrics appear to...
Your problem may be one of the following:
First check or just replace the fuel filter. Usually located under the car in front of the rear axle, drivers side.
Next, the fuel pump may be worn out. Usually they get loud or stop working (running).
Next, check the fuel pressure regulator. Usually located on the front fuel rail, drivers side.
Is the vacuum line attached? Not leaking or rotted?
Also, do you smell a strong fuel odor when it won't start? May be one or more stuck-open injectors, or the coil pack is bad.
Checking these in the order listed will more than likely fix your problem.
The clicking noise indicates the battery can no longer run the starter, which also means the fuel pump won't run either.
It could be a fuel issue. How old is the fuel filter? Can you hear the pump run for a few seconds when you turn the key on? Try turning the key to ON without trying to start engine three times waiting for the pump to stop running each time. Then try to start the engine. If it starts, Its a form of Vapor lock caused by the extreme heat we have had lately, and a weak fuel pump.
If none of this works, try a new fuel filter first. From there have someone check the fuel pressure regulator and then the pump. If you are in need of a new pump, take my word for it and spend the money to get one from a Dealer, and not from your favorite parts store. Most parts store parts are made in China and they are JUNK.
Aug 28, 2011 | 1997 Chevrolet Blazer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Do I need to use 91 octane gas in my bike?
What does the manufacture say to use? if they say to use it there must be a reason. It won;t hurt to try a lower octane but listen carefully for engine knock, if you hear it get back to the highere octane fuel. stokes make it real hard to hear the knock but the performance will be deminished. I personally use the higher octane when ever I can get it but I use mid grade and if only regular is available I use it with no problem.
Mar 21, 2011 | 2005 Honda CRF 230 F
Octane Fitness Q35c Elliptical Cross Trainer Logo
89 people viewed this question
Top Octane Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Octane Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
