Question about CAS LP-1000-NP LP-1000 Series Label Printing Scales with Tower
Printing problems not printing until I shine flashlite in the eyes of scale
08 saturn vue 2.4 L starter swap.. What is missing everywhere is how to find and/or remove the top bolt. everything else you can figure out just by looking ..even with a mirror I did not find it...
Is this what you have? And a problem with top bolt? Sometimes I use a mirror and a flashlite together to see into hard to get at places. You shine the flashlite into the mirror and it reflects the lite into the dark spot.
If there is gap above the starter motor, use a long extension, about as long as the starter with proper socket. I don't know if removing starter solenoid would help or not? Just a thought.
Feb 09, 2018 | Saturn Cars & Trucks
To enable back display driver no picture at my screen laptop
shine a flashlite on the screen, see if anything shows. if so, backlite is out
Aug 03, 2017 | Computers & Internet
Sharp LCD tv has sound and no picture, will a reset work?
Do this first. Shine a flashlite on the screen to see of you can see a picture with the TV on and listening to a program. If you CAN see a picture the backlight drivers are bad If no picture the T-con board is bad. You can get parts from here :www.shopjimmy.com
Jun 25, 2014 | Sharp LC-32SB24U 32 in. LCD TV
Loud clicking noise on startup
Had the same problem with machine gun noises. Solved same. Simply turn printer off. Open door. With a flashlite, look inside to the right side where you'll see a small tray that slides forward and backwards. This is the cartridge cleaner. Push the tray forward (away from you) until it stops then move it backwards until the little black tab on the right is 1/2 inch from the metal part of the carriage. Close the door. Turn printer on. All done. Print something.
Oct 28, 2010 | HP D1660 InkJet Printer
I was wondering about the calibrations in the center between the eye pieces' and how they are used
It's there to help you set the binoculars quickly to your own inter-pupillary distance. Just make a note of the number the pointer on the scale is at when you find a comfortable setting for your eyes and then when you next use them just set the pointer back to the same number. The scale is the angle of the yoke, and you'll often (but not always) find that the scale works on other makes and models as well to help you quickly set the binoculars up to your own preferences. The left eyepiece will also have a dioptre scale (not always accurate) so when you have sharp right eye focus, adjust the left eyepiece until you get sharp left eye focus as well.The scale on the eyepiece indicates how many dioptres (+/-) your left eye is different to your right eye. If you know the left eye setting and the yoke angle, you can quickly adjust most binos to your own comfort settings. Fixed focus binoculars are different in that they have dioptre adjustment on both eyepieces, so left eye settings from regular binos are not directly useful on fixed focus binos, but the yoke angle may still apply.
Sep 01, 2010 | Bausch and Lomb Legacy 12-1056 Binocular
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
Mar 22, 2010 | Adobe Acrobat 6.0 Professional for PC
Headlights shining high are the bulbs upside down
it's very difficult to install them upside down,but i guess anything is possible. wait until dusk,shine the lights on a flat surface and attempt to adjust until the lights look like they are shining in the center.
Apr 29, 2009 | 1998 Plymouth Voyager
Ice dispenser
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back with the complete model number from the fridge if you need more help.
Nov 14, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
CAS LP-1000-NP LP-1000 Series Label Printing Scales with Tower Logo
Top CAS Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a CAS Office Equipment and Supply Expert? Answer questions, earn points and help others
