Question about Sony KV-32XBR85 TV
Lg tv. moved it now it won't turn on
Moved my 37 lg tv.. now it is dead. the cable is live, but the tv wont do anything
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
My LG 32LD320 won't turn on. I have no standby light and have even tried changing the fuse. Help please!
If total dead best way is to follow the AC voltage from power cord inside the set to see where voltage is lost.
Also , were you having any problems having to turn set on several times to get it on?
Mar 20, 2012 | LG 32LD320 32 HDTVReady LCD TV
Hi, my tv wont come on. the stand by light turns on and off (as if it were not turned on, just on stand by mode) in red, then it turns blue/white as if it was going to come on and it simply turns off...
The power supply is dead,Theres a leak capacitor,you can identify those capacitor if leak of deffect when the top is round shape and usaully the normal capacitor is flated at the top.Try to replace capacitor at the power supply.
Jul 12, 2011 | LG 37 37LV3500 LCD TV
My Haire HL37E is stuck in the multimedia mode and wont respond to anything, what is my solution
get a niversal remote and use the codes for lg not for haier,,, once its programed (turns off/on) press last/channel button that`s it
Sep 08, 2010 | Haier HL37E 37 in. LCD TV
No PC Signal on my LG 37" LCD TV?
ON TV MANUAL SETUP PC INPUT ON
CHECK YOU PC ADJUST TO 60HZ....
May 03, 2009 | LG 37LP1D 37 in. LCD Television
I moved my lg37lp1d flat screen from one wall of the room and now it wont power on anymore. the power light will come on and then go off, and tv never comes on. what's wrong?
What you most likely have is dried out capacitors in the power supply. When you un-plugged the set and everything had a chance to discharge, the capacitors in question could not charge up again, causing the problem you have. Any local service center should not have a problem repairing it. I do them all day long. It might not be very old, however, the power supply runs 24/7 as long as you have it plugged in to a live outlet. I tell customers to connect it to a switched outlet, meaning when you turn off the light switch that particular outlet is dead, creating longevity for the power supply.
Apr 23, 2009 | LG 37LP1D 37 in. LCD Television
37" lg television
sounds like u have a dead solder joint or loose connector. poor workmanship LG (formerly known as GOLDSTAR is known for)
Dec 05, 2008 | LG 37LC7D 37 in. LCD HDTV
Televison & Video Logo
13 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
