2080-9024 dialer programming manual
Do you have a programming manual?
2 Suggested Answers
SOURCE: Programming the "Memory Dialer"
You may try this: 1. Pick up the handset and listen for a dial tone. 2. Press and release the STORE button. 3. Enter the phone number(up to 16 digits)you want to store into memory(The telephone number will not dial out) 4. Press and release the STORE button. 5. Press a one-digit number(0 - 9)on the keypad to store the phone number into the desired memory location. 6. Hang up the phone by returning the handset to the handset cradle on the base. 7. To store more phone numbers in memory, repeat steps 1 - 6 Good Luck !!
Posted on Jul 19, 2007
Tip
How to Operate a Home Security System Without a Contract
Many homes have alarm security system installed, even though the current tenants may not have been the ones who paid for it. Some did pay for it but just can't afford the high monthly cost of alarm monitoring. Many people don't realize that once the alarm security system is installed only the monthly monitoring fee stands in the way of free home security. The alarm system still works without monitoring, and it is easy to configure on your own.
  • Install the dial capable motion detectors in place of the entryway motion detectors. The mounting directions and hardware will be included in the motion detectors' packaging. Often the old motion detector's hardware will mount the new one.
  • Connect phone lines to the new motion detectors as instructed by the manufacturer. Usually the lines connect from the new motion detectors to a phone or third-party dialer.
  • Program the dialer or the dial-capable motion detectors to dial the phones of your choice. Your cell phone is usually the most important phone number to program into the dialer to alert you quickly if there is an intruder.
  • Arm the alarm as you normally would. If there is an intruder, the new motion detectors will sense the movement and will dial your phone to alert you.
  • Tips & Warnings
    • Consider replacing the motion detectors that cover the windows and alternate entry and exit points, especially if you have a large home or one with several different entry doors.
    • If the dialer-enabled motion detector is capable, program a second and third phone number into the dialer to maximize effectiveness. Dialing your cell and your neighbor's home phone, for example, would be more effective when you are away from the area.
http://www.securityalarmchina.com/
on Mar 29, 2016 | Home Security
Entry delay is set correct but I want it to call out more quickly when the alarm actually goes off. It seems to wait too long. Do the entry delay and the actual alarm call out delay always the same?
Installation manual is here:
http://www.sdilink.com/GE%20Manuals/Simon%203%20Install.pdf
Programming starts on page 17.
Dialer Delay is option 17 on page 29. It's default setting is 30 seconds.
To set Dialer Delay, press:
1.Add
2.Option #
3.17
4.Use the numbered keys to enter the time 005 -
254 seconds (all entries must be 3 digits).
5.DONE
To turn off Dialer Delay, press:
1.Delete
2.Option #
3.17
4.DONE
Hope this helps.
May 10, 2011 | GE Security Simon 3 Wireless Home Security...
I have a Panasonic Easa-phone Model KX T-3135. I need information on how to program the memory to use the automatic dialer keys.
Panasonic ESA-PHONE - KX-T3135
Program instructions for the "Automatic Dialer"
On the right side of phone set the 'Memory' switch from 'Set' to 'Program'
If programing the upper entry of a 'Automatic Dialer' buttons:
Press the button - enter the phone number as it needs to be dialed - press the 'Memory' key on the left side of the phone's face.
If programing the lower entry of a speed dial buttons:
Press the 'lower' button on the left side at the bottom of the 'Automatic Dialer' pad;
When all entries are complete, on the right side of phone slide the 'Memory' switch from 'Program' to 'Set'.
May 03, 2011 | Cell Phones
Hello. I have over 300 numbers programed and we recently moved and now we have to dial "9" before the number. Is there a way I can pre-program the fax to plug a "9" before dialing?
If the machine is one ofthe newer variety where it is connected to the PC ...then you can alter your "Auto-Dialer" from your PC.
If it is not a PC connected machine then you will have to go in manually and change the programming on each individual number.
Sep 16, 2010 | Muratec Office Equipment & Supplies
While running the CE100 Dailer for Tata Photon+ internet connection, system is throwing below error message Unable to execute file: C:\Program Files\CE100 Dialer\Driver\HaierDcService.exe Create...
If you reinstall the CE100 dialer software that will fix the problem.
Sometimes if you have a virus or malware problem it will take this out. So if you just cleaned your pc and got this thats why. The error is just saying windows wanted to run the dialer but it wasn;t where it was expected to be. somethig either deleted or moved it.
Aug 20, 2010 | Computers & Internet
I AM USEING WINDOW XP. SO CREATING SOME PROBLEMS FOR RUNDELL FILE. HOW TO SLOVE THIS PROBLEMS PL TELME SIR.
You can solve the problem by going to the below link and also u can follow the steps provided
Step 1:
trusted_vendor.gif Remove Rundll.exe and Rundll32.exe infections using True Sword - our awarded program. True Sword will find and liquidate this problem and more than 524 977 other perilous threats including trojans, spyware, adware, riskware, problemware, keyloggers, dialers and other kinds of malicious programs in several seconds. True Sword scans your hard disks and registry and destroys any manifestation of malicious programs - to protect your privacy and your operating system in the fastest, easiest and the most handy way. Standard anti-virus software can do nothing against privacy breakers and malicious programs like that. Get rid of trojans, spyware, adware, trackware, dialers and keyloggers in one click right now!
Download True Sword now for free
or you can visit the below link
Step 1:
thanks
May 19, 2010 | Computers & Internet
How to program numbers into the memory of the fax machine.
Here is a link to your Toshiba DP-85F Operators Manual. Reference pages 65 through 80 to program Abbreviated Dialer Registration, One Touch Dialer Registration, and Group Number Registration.
http://209.167.114.38/dealers/opg/support/manuals/DP80F_85F.pdf
Dec 03, 2009 | Toshiba DP-85F Fax
How do you program Auto Dials for BIS-34D?
We have these exact phones in our Central Control Room. We do not have instruction manuals for them either and they are discontinued. However, I figured out how to program external phone numbers into the speed dialer.
First, put the switch on the left-hand side of the phone (near the handset) to the "P" position. This will make all the lights and ringer go off. You are now in program mode. Next, press a button on the right-hand side of the phone that you would like to program a number to (say the top, right button). Press the button and it should say "blank." Then, go ahead and enter the telephone number that you want for that button. You should see the number appear in the digital display up top. After you've done this, press the top, right button again and this programs the number into that particular button!
Repeat the above steps for multiple auto-dialers going on down the column.
I hope this helps!
Dec 13, 2007 | Avaya AT&T Merlin BIS 34D Telephone
Jun 27, 2007 | Northwestern Bell Classic Favorite 52860...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
