Question about Olympus TOUGH TG-310 Digital Camera
Camera makes a ringing noise then shuts off
When every i put it on the chager it makes a ringing noise then shuts off
I have same problem too....who can help me fix it?please .....
Posted on Jul 26, 2015
How can I change ipso washing machine drum bearing
drum bearings chager bullets inside dead
Oct 20, 2014 | Washing Machines
Vg-120 wont open
I know this is just southern inginuity but ours did the same after a trip to the beach. my husband took a knife and removed the outer rim, to loosen the sand out, then we had to tape the ring back on. still works. but if you don't won't to damage your camera, you might not want to do it that way.
Jul 27, 2012 | Olympus Software VG-120 Digital Camera
The lens won't come out - it makes a buzzing noise but won't open. Like it's jammed?? Olympus FE-46
Hi.
This error indicate that focusing ring got stuck or jammed. What you can try to do is spray some compressed AIR into the lens to try to free up any sand or dust that may have worked its way in. If that doesn't help, you can gently bump the camera to try to free the focusing ring.
or.......
You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Jul 04, 2011 | Olympus FE-46 Digital Camera
I have a vivicam and it didn't come with a chager this is my frist vivicam ever what do i have to do to chager it?
I sense that your camera is not actually the DVR-390h in the title. That is an older multi-media device that came with a lithium battery and a charger.
If you bought your camera new and got no charger with it, it may be that your camera uses ordinary AA batteries, which can be rechargeable or just disposable Alkaline cells. You would have got a set of alkaline AAs with the camera, and when these expire, you just put in a fresh set, that you can buy anywhere. DON'T use cheap zinc or "long life" AAs, though. They are not up to the task, and can leak and corrode your camera.
If you want to, you can buy a set (or two sets, to have spares) of rechargeable AA cells. Get high capacity NiMH type, preferably 2300mAH or 2700mAH rated ones. You can often buy these with a charger relatively cheaply. These batteries can last longer, per charge, than alkalines, and will work out cheaper in the long run.
Oct 31, 2010 | Vivitar DVR-390H Digital Camera
Camera shuts off after E18 error code
You have most likely dropped the camera or banged it against something while the lens was out. This situation causes the brass pinion gear to shear teeth off the plastic ring gear on the Inner Lens Housing. It may also cause the guide pins to jump their track. If this is the case the repair bill usually exceeds the value of the camera and you are probably better off selling it for parts on eBay and getting a new higher resolution camera.
Dec 21, 2009 | Canon PowerShot SD300 / IXUS 40 Digital...
My chager for v tech camera isnt working. wer could i get a replacement?
Try www.sears.com the parts dept have make and model ready! Also try radio shack just take the old one with you!
this should fix ya!
Dec 16, 2008 | Cameras
Sand in focus/zoom ring
You have to disassemble complete lens assy for cleaning.
Jul 28, 2008 | Sony Cyber-Shot DSC-F717 Digital Camera
Loud ringing noise
it is due to no signal from the source.
Sep 29, 2007 | Apex Digital AT2008S 20" TV
W1 Making noises....??
The W1 uses metal rings that slide in place with a tiny hole in the middle to give the required apperture it does not have a diaphram that closes and opens to give the apperture... so what you here is the sound of changing the suitable ring ( or disc) with the apperture ... You can look in the camera (lens side) and change appertures, you should be able to see this happen ... don't click with flash though :) The sound is very low though if you here a loud click there's something wrong.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Olympus TOUGH TG-310 Digital Camera Logo
125 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
